Vendor Showcase Forum for Vendors to display their products and specials
SCT X4 Power Flash Programmer Video 1996-2014
Old Mar 20, 2014 | 08:24 AM
Steve@CJPP's Avatar
Former Vendor
SCT X4/7015 Mustang X4 Power Flash Programmer with Tune 96-14
This is the new SCT X4 Power Flash Computer Programmer with a Custom Tune for all 1996-2014 Ford Mustangs, 2013-2014 Focus ST's and 2011-2014 Ecoboost F-150's.
The next generation hand held tuner is here, in a big way! Introducing the all new X4 Power Flash Computer Programmer from SCT! The new SCT X4 Power Flash Computer Programmer is styled after the ever so popular SCT X3 programmer with the same great features, but with a slew of all new user friendly features to really set this tuner apart from the rest.
All New SCT X4 Features and Benefits:
- Built-in WiFi connectivity attaches to your local wireless network for easy device updates
- Full color LCD display with an auto dim feature and user adjustable portrait/landscape modes
- Pre-loaded with dyno proven, track tested performance tunes for serious horsepower gains
- Holds up to 10 custom tune files for maximum on-device selection for any occasion
- Monitor your Mustang's PCM data live in real-time on screen or using SCT's LiveLink Data Logging software
- All new redesigned compact design measuring 2-3/4" wide x 5-1/2" high
Additional X4 Features:
- Increases Horsepower and Torque
- Reads/Clears Diagnostic Trouble Codes
- High Speed Data Logging/Monitoring
- User Adjustable Vehicle Parameters
- Backs Up Factory Tune
- Free Data Logging Software
- Dual Analog Inputs
- USB Interface Cable Included
- Installs Quickly and Easily
From the factory, your vehicle's computer is calibrated for the general public, designed with the average driver in mind, not the performance driver. This not only leaves valuable horsepower and torque hidden inside your Mustang, Focus or F-150, but it also makes for a less than thrilling driving experience. The all new X4 Power Flash Computer Programmer from SCT unlocks your vehicle's hidden performance potential by optimizing your vehicle's computer for maximum horsepower and torque, improved throttle response, solid shifts and even increased fuel mileage.
The X4 Power Flash Computer Programmer will come with one custom tune from CJ Pony Parts and will accommodate for any modifications you have made to your 1996-2014 Ford Mustang, 2013-2014 Focus ST or 2011-2014 Ecoboost F-150
Pre-Loaded and Custom Tune File Adjustable Options:
- Rear O2's Disabled
- Fuel Injectors
- Charge Motion Control Valve Delete Plates
- Speed Limiter (User Adjustable)
- Idle Speed (User Adjustable)
- Traction Control
- Spark Modification by RPM (User Adjustable)
- Wide Open Throttle Fuel Control
- Shift Firmness Control (Automatic Transmissions ONLY)
- Axle Ratio (User Adjustable)
- Tire Size (User Adjustable)
- Aftermarket Intake
- Fan Control (User Adjustable)
- Rev/RPM Limiter in Drive (User Adjustable)
- Rev/RPM Limiter Neutral (User Adjustable)
- Wide Open Throttle Shift Points by Gear
- Stores Stock Tune
- Supports Custom Tunes
In order to program your new SCT X4 device, CJ Pony Parts will need the computer code for your vehicle and the modifications done to the car. Please fill out all the required information so that we can provide you with the best performing tune possible.
*Depending on the vehicle, some tunes are able to be modified by the user from the hand held tuner, like the gear ratio and tire size tunes, etc. Not all parameters of a tune are user adjustable, these adjustments are included in a CJ's tune file.
For more products from SCT available at CJ Pony parts check out:
SCT Performance | CJ Pony Parts
For more computers and programmers available at CJ Pony Parts check out:
Mustang Computers & Programmers | CJ Pony Parts
May 3, 2026 05:42 AM
trackpack13gt
Jul 25, 2017 05:29 PM
FordOfMurfreesboro
Nov 14, 2015 06:09 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Sep 24, 2015 08:15 PM
