MRT Hood Struts
MRT Hood Struts
These aftermarket Mustang hood struts eliminate the factory hood prop rod and give you the clean, pleasing appearance every engine compartment deserves. MRT Hood Struts are great for both show and street Mustangs - don't let that hood prop distract from all the power you've packed under the hood.
MRT joined design teams to develop hood struts for your 2005-2011 or 1999-04 Mustang. MRT's Mustang hood struts have since become one of MRT's bestselling products. The consistent customer satisfaction we have observed in response to our hood struts confirms their quality design.
MRT Hood struts reuse OEM factory attachment points (Direct bolt on) and require NO holes drilled anywhere. These hood struts are easy to install on your Mustang - the only tool required is a 10mm wrench.
MRT Hood Struts will not necessarily hold up aftermarket hoods. Some light weight aftermarket hoods may bow just forward of the Hood Strut Bracket, causing a gap between the closed hood and fender; while some heavy aftermarket hoods may weigh too much for the hood struts to support in the open position.
All MRT hood strut brackets are finished in black or silver powdercoat, and new faux Carbon Fiber Finish.
http://store.mrt-direct.com/hoodstruts.html
http://store.mrt-direct.com/80a012-blackcf.html
9/16/15 06:44 PM
