Vendor Showcase Forum for Vendors to display their products and specials
Introductory Offer on Fox Body Hood Struts $89.99
Old Jan 11, 2011 | 08:15 AM
MRTracing's Avatar
MRT is proud to announce the MRT Hood Struts for 1979-93 Fox Mustangs. The MRT Hood Struts eliminate the factory hood prop rod and provide a clean, functional, performance look. They are the first hood struts for Fox Mustangs on the market and are designed, engineered and manufactured in the United States.
The MRT Fox Mustang Hood Struts reuse the factory attachment points and are a direct bolt on. They do not require any holes to be drilled. The hood struts are very easy to install and require only a 7/16 wrench.
The MRT Hood Struts are available in all exterior vehicle colors or a high tech, black carbon fiber look.
MRT, headquartered in Plymouth, Michigan is a performance aftermarket engineering, customization and sales company that specializes in automotive exhaust, styling and performance
http://store.mrt-direct.com/80c000blk.html
Old Jan 11, 2011 | 08:47 PM
hi5.0's Avatar
Will they work with bolt-on fiberglass hoods? Just wondering because wouldn't want them to place undue stress on the mounting points if they're designed for the heavy factory steel hood.
Old Jan 11, 2011 | 10:48 PM
Dang the factory hood is heavy.
Old Jan 12, 2011 | 01:33 PM
MRTracing's Avatar
If the factory hinges were used it "should" bolt up. A higher or lower gas cylinder might be needed which we should be able to assist you with. If you have any further questions please do not hesitate to give us a call at 734-455-5807.
JTB
Motorsports
Oct 29, 2015 09:07 AM
seaclam
Sep 25, 2015 01:29 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
JTB
Motorsports
Sep 7, 2015 10:20 PM
