Digital Torque Wrench - Special
Digital Torque Wrench Special - Extended for the Holidays
EXTENDED UNTIL JANUARY 12TH
As a new sponsor of this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: MSOURCE
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till Nov. 15th, and is only for the lower 48 states. Extended until January 12th.
What you want to do is pick the wrench with case ($150 retail) from the pull-down menu. Then press "add to cart". You will then see a place to enter a discount/coupon code and your zip code. Enter the code in and press update cart. You will then see the price be $99. You can then press the Google Check out and it will be for $99.
Any problems, you can call me at 312-884-7644 and I can do it over the phone.
Thanks.
BLMW
Thanks.
BLMW
This looks like a great product, but in the past I've had less than stellar luck with digital torque wrenches. I didn't see a warranty listed in the product description or on your site. Does this product have any sort of warranty on it?
Warranty
We have received a bunch of requests to put this information on our website. It is something we are planning on doing next time we make changes.
BLMW
Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. We have a repair/calibration facility located in Chicago in case anything ever does need to be done to the wrench.
BLMW
BLMW
BLMW
We have gotten a number of requests from members who missed the deadline, so we are going to extend this special for one more week (until January 12th). Thanks for the orders and support.
