2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade!
http://www.diodedynamics.com/images/...e1_600x115.gif 2013-2014 Ford Mustang DRL LED Boards http://www.diodedynamics.com/images/...rd-Collage.jpg 2013-2014 Ford Mustang DRL LED Boards Upgrade your Mustang's factory DRLs with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2013-2014 Ford Mustang. Your order includes a full set of panels, as well as drivers to safely and reliably power them. From the factory, the DRLs in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish. Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included). Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals. To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal. There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty. Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels. All Diode Dynamics products are backed by a 3-year replacement warranty. 2013-2014 Ford Mustang DRL LED Boards If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033 *PM us for the free-shipping code* (U.S. forum members only) Thanks for looking! Nick C. Diode Dynamics |
http://www.diodedynamics.com/store/m...img_4640_1.jpg
Customer Submitted Photo These LED Board replacements fit all 2013-2014 Mustang models Nick C. |
1 Attachment(s)
What other controllers work with these?
Can you get a Black Controller? |
Any of our RGB controllers will be compatible, but you'll lose the benefit of the added white unless you are using an RGBW controller.
Nick C. |
I want to order these. Is it true it will take 6 to 8 weeks?
Any sooner? Do you make a smaller black controller? or just Black? |
Please contact us for more information: (314) 205-3033
Thank you! Nick C. |
http://diodedynamics.com/images/ford...ide%20Shot.jpg
Customer Submitted Photo - Notorious Photography: https://www.facebook.com/TheNotoriou...raphy/timeline Nick C. |
http://www.diodedynamics.com/store/m...reen_front.jpg
http://diodedynamics.com/images/ford...T500_Green.jpg
I want this but I also don't want the cops pulling me over lol
Originally Posted by renee29581
(Post 6993442)
(RGBW = Multicolor + White) Thanks! Nick C. |
Originally Posted by Diode Dynamics
(Post 6993456)
Luckily they have a built-in white so you can stay perfectly road legal while driving! :metal:
(Post 6993470)
Yea but not to sure I want to keep it in white for 120 bucks either lol:banana:
Nick C. |
(Post 6993471)
With the RGBW boards, you'll have the best of both worlds. You can decide which color you'd like to run at any time and still be able to switch to white.
Nick C. |
(Post 6993481)
Maybe if I can get them for 60 bucks I'll get them..until then 120 is too high!!!
Nick C. |
