Sponsored by:
Sponsored by: CARiD
Will the 2015 IRS have wheel hop
Old May 21, 2014 | 07:05 PM
2snake's Avatar
The Cobra Mustangs of the past with the IRS had terrible wheel hop.. I sure hope this doesn't happen again
Old May 21, 2014 | 07:31 PM
todd03blown's Avatar
In the line-lock video, there has been zero wheel hop. Hope that is what we see from the factory produced cars. I feel confident it will.
Old May 21, 2014 | 08:33 PM
Tony Alonso's Avatar
That was a reverse-engineered bolt-in configuration in a chassis that was less rigid than what the new one will be. In addition, the big power of the supercharged engine was a contributing factor.
The new car had IRS designed in from the start, and the technology to design and engineer the unibody is vastly different than what was done for the previous generation.
It would be surprising if there was this behavior on the new car.
Old May 22, 2014 | 03:18 AM
newpony's Avatar
Let it be known that a lot of people her at TMS has complained about terrible wheel hop with the current generation Mustang that has a SRA. In my opinion wheel hop is more a function on how the car was engineered than whether it has IRS or SRA. Also if you increase the engine power via aftermarket there is a chance you can reach the limit of what the stock rear suspension can handle. That is why is always good advice to upgrade the suspension components first and then go ahead install your turbo or supercharger.
Old May 22, 2014 | 09:08 AM
xlover's Avatar
As I understand it the improved geometry that results in less squat and dive has a similar effect in reverse on the wheels being able to rebound off the pavement under torque stress. Maybe a suspension expert can clarify.
Old May 22, 2014 | 11:09 AM
My lord. I cannot believe this is a thread. Seriously? And your second post?
Old May 22, 2014 | 01:03 PM
Fox9350's Avatar
Disclaimer as someone with pretty limited mechanical knowledge of cars, this is my understanding, that the 2003/2004 IRS in the cobra was just kind of shoehorned in there this 2015 has been engineered and tested from day 1 to use it.
Old May 22, 2014 | 01:09 PM
So are the Camaro and Challenger. And they both have wheel hop issues with their IRS.
Old May 22, 2014 | 01:21 PM
AlsCobra's Avatar
A Man Just Needs Some....
It may have some wheel hop issues just like anything with IRS. Or just a lot of spin and fishtailing. But all of these issues can be easily resolved with better tires or a little aftermarket suspension work. We really won't know till they come out and the drag racers start putting it to the test. It very well may work beautifully right out of the box. Everything else is just speculation. We know for sure that it will really handle in the curves though. If you have doubts, just wait and see what others are posting. As of now, none of you have the answers and there's no point in this thread.
Old May 22, 2014 | 02:07 PM
Hey - TMS is slow enough as it is these days. You should be encouraging more speculation.
Old May 22, 2014 | 03:30 PM
This.
Old May 22, 2014 | 06:30 PM
So why ya posting in it?
Old May 22, 2014 | 08:06 PM
rhumb's Avatar
If that line lock video is any indication, it's as steady as a surgeons hands. Both IRS (the one cobbled together exercise) and stick axle Stangs have suffered from the green light jitterbug, so I don't think IRSs are necessarily prone to this.
Old May 23, 2014 | 05:50 AM
MRGTX's Avatar
Us wheelhop sufferers will attest that even the hip-hoppin'est Mustangs can be made to smoothly spin the tires with the right set of conditions/technique (unfortunately, those moments are rare).
The line lock demonstrations look promising and I'd like to think that they wouldn't provide a feature that would put owners directly at risk for wheelhop related driveline thrashing/breakage...but dumber things have gotten through.
In other news, the staggered leaf spring suspended/live axle in my 40 year old Mopar A-Body has never wheelhopped. Go figure.
Old May 23, 2014 | 06:38 AM
1bad01gt's Avatar
I heard that it won't only have wheel hop, the car will explode when trying to do a burnout...
Old May 23, 2014 | 07:31 AM
AlsCobra's Avatar
Postwhoring. Duh.
Old May 23, 2014 | 10:36 AM
Postwhoring. Duh.
This.
Old May 23, 2014 | 05:46 PM
ford4v429's Avatar
legacy Tms Member
on mine (06) dropping tire pressure even a little made hop go away with the Pirellis, never did it with the 255/45-18s at full or reduced pressures(changing pressures on the wider tires also had little effect on 60' times?) listen at about 25 seconds in the video below, thats about the closest to 'wheel hop' as Ive had with the 255s...
yeah, I know that was a sloppy spinning on the limiter launch, but had kids in the back seat, its more fun with screeching tires ya know
Old May 23, 2014 | 07:18 PM
tom281's Avatar
Yep and the Srt8 chally I had took more than just basic suspension mods to get rid of it. At least with the manual trans anyway, the autos were much easier because the converter absorbed a lot of it.
Old Jan 4, 2015 | 08:09 AM
2snake's Avatar
Now that the cars are released has anyone had any issues with wheel hop
