Sponsored by:
Sponsored by: CARiD
launching, times, shifting
Old Nov 2, 2014 | 08:18 PM
Bert_grblue's Avatar
Hey TMS people, im back with a 15 GT base 6spd. Love the car, love the ride quality. Ive only had it since Friday so I'm still learning the car. I tried launch control and timed a 1/4 mile pass. Tach confuses me a little bit. Is red line 6500 or 7000? What rpm y'all launching at? I tried a couple of passes and did 13.4 on stock everything, asphalt no burnout. I think I may be shifting too early. Any one have any experiences or input
Old Nov 3, 2014 | 12:45 AM
2012GT's Avatar
If you bought the car for 1/4 mile times, you should've got an 11-14' GT. If you got the car for road racing, you should've got a 15' Camaro. Both are eating the 15' GT in these respected areas.
Old Nov 3, 2014 | 02:53 PM
Anthony k's Avatar
"Eating" is a bit far stretched to say the least.
Old Nov 3, 2014 | 06:36 PM
5.M0NSTER's Avatar
How about "consuming"
In all honesty, it is pretty close. But how does that saying go? Doesn't matter if you win by an inch or a mile.
Old Nov 3, 2014 | 08:22 PM
It's not the reason I bought it but I do like to roll race. If you wanna bash thread by all means go make one. All I'm looking for is others information
Old Nov 3, 2014 | 08:24 PM
Jazzman442's Avatar
Monster You nailed it..
Look on the bright side. If the OP bought it for Drag racing wait a while Ford Racing has a Solid Axel upgrade for those who want to Drag Race..
Old Nov 3, 2014 | 11:07 PM
Five Oh Brian's Avatar
Or, check out the Ford Racing .99 video and you'll see that they offer heavy duty half shafts and a rear subframe upgrade so that the IRS can survive under repeated drag racing. I suspect there will some diehard drag racers who buy '15's and campaign them successfully against those of us with '11-'14 GT's.
Old Nov 4, 2014 | 12:43 PM
RandyW's Avatar
Lesson learned. I guess if someone buys a 2015 GT and they have any interest at all in quarter mile times, they better keep their thoughts to themselves.
Bert, I'm not into drag racing so I have no advice on technique. I can say though, that the redline on your engine is 7000 rpm. As long as the engine is good and warm, feel free to wind it out. The Coyote loves to howl.
Old Nov 4, 2014 | 02:34 PM
Originally Posted by RandyW
Lesson learned. I guess if someone buys a 2015 GT and they have any interest at all in quarter mile times, they better keep their thoughts to themselves. Bert, I'm not into drag racing so I have no advice on technique. I can say though, that the redline on your engine is 7000 rpm. As long as the engine is good and warm, feel free to wind it out. The Coyote loves to howl.
Just don't dump the clutch at 7k if you're all stock. That will be a major problem.
Old Nov 4, 2014 | 07:16 PM
Lol no dumping at 7k , thank good sirs thats what I wanted to know, as for 1/4 mile I'll probably still do it �� but I do like carving as well. Thanks and can't wait to see what platform is capable of.
Old Nov 4, 2014 | 07:22 PM
Jazzman442's Avatar
Ford is coming out with a solid axle. IRS does not work in Drag racing. The tires want to either go toe in or toe out and change camber that is why IRS does not work. Last time I check Ford said they will have the Solid Axel ready second quarter of next year.. Hey even NASCAR does not use IRS. But Hey it makes for a great road car.
Old Nov 4, 2014 | 07:55 PM
Joeywhat's Avatar
Good grief, guy asks a simple questions and it's all Camaro vs Mustang and IRS vs solid axle.
What a **** show.
Old Nov 5, 2014 | 06:17 AM
JoeMidnight's Avatar
If you turn off all of the nannies, with your GT, launching at even 4k will likely just make the tires spin and cause you to go nowhere....
Old Nov 5, 2014 | 06:51 AM
5.M0NSTER's Avatar
With stock everything the recommended launch RPM for my 2014 GT TP was 1800. I guess you could start there and work your way up. With 275s on the back you might be able to launch at 2000, but I'd guess that anything over ~2500 you'll spin and hop. This depends on how quickly you get off the clutch of course, but I'm assuming ~0.4s to fully disengage clutch.
I've gotten some good 0-60 time on my car with 275s all around launching at 2700 and taking ~0.8s to let the clutch out. Good luck and let us know what worked best with the new setup on these cars
Old Nov 5, 2014 | 07:04 AM
mustang5o's Avatar
What are you shifting at? I've had my car at an 1/8th mile track and I sping through almost all the gears. I've tried different approaches but nothing seems to work well with the stock Pirelli tires (probably part of the problem). Although they seem to grip pretty good on regular streets when I take my chances at a good 0-60 run or push it in some corners.
OP, I think tire size and type on the base GT is going to limit grip quite a bit.
Old Nov 5, 2014 | 08:27 AM
5.M0NSTER's Avatar
I agree about the stock pirellis. Can't push much past 80% WOT in 1st without spinning. Wider, stickier tires on the back certainly help.
For best times I shift at 6600, since the Coyote makes peak power at 6500rpm. If I roooooooooolll onto the throttle in second I can avoid spin. For 3rd I up-lift during the shift, then floor it.
Old Nov 5, 2014 | 08:51 AM
RedCandy5.0's Avatar
STEEDA
tukatz
Oct 13, 2023 10:01 AM
ssjbuu
Aug 28, 2015 08:55 AM
cloud9
GT350
Aug 18, 2015 01:34 PM
db2797
Jul 28, 2015 07:34 PM
