Sponsored by:
Sponsored by: CARiD
Hood activated engine compartment light?
Old Mar 21, 2018 | 11:15 PM
BluePonyGT's Avatar
I swear - along with the lack of hood struts the fact that there's no light circuit that activates when the hood is up is frankly mind-blowing. Hell, my wife's '99 tahoe with a ga-jillion miles on it has a bullet-proof light in the engine compartment, so when I'm forced to pull the intake in the pouring down rain to find out if I finally cracked the block due to overheating (only to find out the temp sensor is messed up) I can see what I'm doing.
Has anyone actually installed one, and if so what did you pick? No, I'm not cool with the string of LEDs that makes my hood look like a chandelier. I just need a simple light bulb with a shroud on it or something.
Old Mar 22, 2018 | 06:58 AM
ZGrand's Avatar
It’ll never put the light where you really need it. I carry one of those LED lamps that straps to your head in the glovebox of all my vehicles - even the one with an under hood light. Just a suggestion.
Old Mar 22, 2018 | 07:06 AM
SpectreH's Avatar
Many cars from the 60's, 70's, and 80's had a light like that. Simply mercury tilt switch inside. Just wire to the battery with an inline fuse. Of course ZGrand has a really good suggestion.
Old Mar 22, 2018 | 07:38 AM
woody24's Avatar
That's crazy! I've never thought about that. Guess my '06 never had one either. I do remember my past cars having one.
I think I just never thought about it because I mounted two fluorescent lights in my garage for the purpose of working under the hood, because I knew that the bulbs we never bright enough anyways.
With LED strips nowadays, you could almost line your hood with them without any issues.
Old Mar 22, 2018 | 12:12 PM
wanted33's Avatar
You would think that in a 45K - 50K dollar car you would get a hood light, and some real hood struts. Oh well, I guess it's a profit thing for Ford.
Old Mar 22, 2018 | 07:54 PM
BluePonyGT's Avatar
Cool - thanks all. In all seriousness I never go anywhere w/o one of these somewhere near my person:
Amazon Amazon
Maybe I'll get an extra and put in the glove box. I was also thinking about the headlamp idea too 'cause holding a light in your mouth gets really old after a while.
If I find something better I'll post it here.
Old Mar 26, 2018 | 10:40 AM
motor12's Avatar
Never had a hood light that was worth a darn, always used a 100 watt clamp on light.
Old Apr 2, 2018 | 12:49 PM
GT227's Avatar
I wired a bunch of LED lights to a mercury switch, right to the battery. I mounted the mercury switch to the hood so when I open it, the lights turn on. When its closed, the lights turn off.
Got a 1-amp mercury switch and LED lights from ebay.
Old Apr 3, 2018 | 05:39 AM
Gabe's Avatar
You can use a mercury-switch-activated hood light from a '95 Mustang, apparently still available on Amazon:
https://amzn.to/2q1azqn
tsunami
Ecoboost
Apr 18, 2015 05:15 PM
rowka
Mar 18, 2008 12:33 PM
05stangkc
Ford OEM Parts {Oem Ford Parts Information & Links}
Jan 20, 2007 08:39 PM
FoMoCo Jeppe
Feb 23, 2005 05:33 PM
Ranger
Nov 15, 2004 11:07 PM
