Sponsored by:
Sponsored by: CARiD
Fit of MGP caliper covers
Old Mar 12, 2022 | 01:56 PM
Pauls02's Avatar
Anyone have a 2021 Mustang GT with 19” wheels that has installed MGP caliper covers? Rears are fine,fronts come very close to rims almost touch,can maybe fit a credit card through.I had to take other side off as it was rubbing slightly now have to figure out how to make it fit.Any ideas?
Old Mar 12, 2022 | 02:12 PM
houtex's Avatar
Take them off and use caliper paint instead?
I mean, honestly, if they don't fit and you can't adjust... the only thing you can do is shim the wheels or start cutting/grinding things, and I wouldn't suggest the wheels...
Other thing is to try calling MGP maybe? Or swap wheels out...
Old Mar 12, 2022 | 03:31 PM
m05fastbackGT's Avatar
This Seems to make sense IMHO
Old Mar 12, 2022 | 05:24 PM
Pauls02's Avatar
I knew they were close when installed but turned freely for 6 months then heard a slight scraping while going slow,LF ok but close,RF just took off,too busy,going to try tomorrow to do something maybe some filing of cover,not wheel,I can see on cover where a slight scraping has occurred.Just wondering if someone else had a similar problem.thanks for ur input!
Old Mar 14, 2022 | 12:16 AM
shaneyusa's Avatar
I agree, take the off. They will likely also make you brakes run hotter than they would. I would be concerned with brake fade around my neck of the woods, but Florida is pretty flat as I recall. .
Jesus Palomera
Jun 24, 2016 09:25 AM
Fear
Mar 9, 2015 10:56 AM
mrp5150
05-09 Exterior Modifications
Aug 23, 2013 11:10 PM
Dfink114
'10-14 Exterior Modifications
25
Feb 25, 2013 05:32 PM
Murdered_Stang
Jun 26, 2011 03:58 PM
