is this common
is this common
Got my 2015 GT PREM. April 1st. It's 5/10. And 1800+ miles on it.
1. I got in it yesterday started it, let it run couple minutes then headed up the road. I shifted each gear normal speed and after I shifted then pushed on the throttle the car sagged or seemed to choke a little. I backed off then pushed on the peddle and it slowly picked up speed after each shift.
2. I was wiping down car and cleaning windshield then after finishing I started it but it sputtered and died 3 times. Didn't want to run. This has happened 3 times. Once the check engine light came on.
Guess it needs to be put on computer and adjusted. I have done nothing to the car except installing magnaflow street cat backs. That should not affect car causing it to die and choke.
Tune isn't necessary with exhaust but probably would help. Only after dealer checks it out first.
Take it to a parts store that offers free scanning and see if there are any codes if it stalled I'm sure theres at least a pending code. Being that low miles its probably something like a loose MAF sensor plug or the like they sometimes get missed on inspection or can rattle loose in shipping. At least if you check for codes before you head to the dealer you have some sort of idea whats up.
Deysha
