Sponsored by:
Sponsored by: CARiD
2015 rear fenders
Old Dec 26, 2013 | 09:20 AM
Wpasko's Avatar
2015 rear fenders
Hose rear fenders sure look like the charger and the camaro to me. Does anyone else think so?
Old Dec 26, 2013 | 01:16 PM
rhumb's Avatar
If only in the broadest sense of having some contouring to the beltline-hips if you will-rather than a single arcing sweep so (too?) common on most of today's cars. Remember that the Mustang originally had similar contouring/hips for several styling generations, losing them by the Foxstang and not really regaining them until 2010. To be fair, somewhat the same could be said of the other two Pony cars.
In the end though, I think this more athletic beltline contouring is both good looking and somewhat distinctive and conveys well, visually through implied musculature, the performance potential of these cars. Each model does execute their own take on this with more than sufficient distinctiveness to clearly differentiate themselves from each other. I'm not sure what stylistic approach might be preferable.
Old Dec 26, 2013 | 02:11 PM
m05fastbackGT's Avatar
I'll add to what Rhumb just posted by saying.. It was actually the Camaro and Charger that took the quarter panel/rear fender hip design from the 69-70 Mustang..
Therefore as far as I'm concerned.. It's the rear fenders on the Charger and especially the Camaro that look more like the Mustang and not the other way around despite the fact that both GM and Mopar tried their very best to re-create their own versions of Ford's design !
Old Dec 26, 2013 | 02:33 PM
Wpasko's Avatar
Yea it does look athletic as you worded it. I do like it. Didn't say I didn't. I knew they kicked the fender out 20mm to give a shelf like the 67. Didn't remember they initially took it from the mustang first- makes sense. I own a 98 stang and a 07 Charger. I do like the new generation
Old Dec 26, 2013 | 05:03 PM
SynisterGT's Avatar
All these words, and no pics. Smh...j/k
Old Dec 26, 2013 | 07:02 PM
Ummm...no!
Old Dec 26, 2013 | 07:32 PM
bob's Avatar
bob
Ummm...no!
Seconded!
The rear at certain angles only partially favors the Camaro, that said, Ford had been considering hips and a proper fastback (err sports roof in Ford speak) since at least 2006.
Old Dec 26, 2013 | 08:29 PM
Knight's Avatar
Needs to be more Astony
The problem with the new car is the lack of side c scoop. They shouldn't have taken that away, looks very much like the Camaro in front of the rear wheels.
Old Dec 27, 2013 | 11:52 AM
Ford wanted to move in a more modern direction and move away from it's previous retro styling..
Although the C scoop/hockey stick is no longer there, it's not completely gone but rather replaced with more modern sharp edge creases..
Old Dec 27, 2013 | 12:07 PM
Here you go Justin
Size:  39.4 KBName:  50_3.jpg
Size:  58.9 KBName:  1969-Ford-Mustang-Mach-1-Rear-Angle-Maroon-sy.jpg
[IMG]https://themustangsource.com/<a href=http://s103.photobucket.com/user/red05bullitgt/media/1969-Ford-Mustang-Mach-1-Rear-Angle-Maroon-sy.jpg.html target=_blank>Name:  1969-Ford-Mustang-Mach-1-Rear-Angle-Maroon-sy.jpg
Last edited by m05fastbackGT; Dec 27, 2013 at 12:51 PM. Reason: Difficulty uploading URL images
Old Dec 27, 2013 | 03:16 PM
Knight's Avatar
no one called the 94-04 retro yet it had c-scoop.
Old Dec 27, 2013 | 08:14 PM
FordBlueHeart's Avatar
More like retro wannabe.
Old Dec 28, 2013 | 02:14 PM
ETNOATS's Avatar
With that thought process it also looks like an Aston, Ferrari, Maserati.....
Old Dec 28, 2013 | 04:51 PM
eric n's Avatar
I think a lot of cars have over the years, had similar rear fenders. From the start I felt this model harkened back to the 69/70 Mach. Looking at it now, I still see those design cues plus more than a little Aston Martin!!! The rear hips are an outstanding feature of the 2015. Then again, I'm a total Koolaide drinker on the new mustang. So far I like it ALL! I hope it stays that way when I see/drive it in person.
Old Dec 28, 2013 | 09:41 PM
wannabe's Avatar
And the picture of the Camaro is just like all the others... the shading of the hips make it look like the color changes from the rear of the door back. It absolutely drives me crazy.
Old Dec 29, 2013 | 09:22 AM
Pretty much the C-Scoop was all the 94-04 had that was really considered as retro..
The 2005-14 is completely retro and when Ford designed the 15MY, they wanted to move in a completely different direction altogether..
Old Dec 29, 2013 | 11:44 AM
Here you go Justin
I don't like how the doors look so close to Camaro.
Old Dec 29, 2013 | 11:47 AM
Knight's Avatar
That's the problem, like the Porsche 911 the styling cues of a Mustang like the c-scoop are not retro they are timeless.
They will fix it on the next remodel, kinda like they messed up the 2005-09 by not including the hips.
Old Dec 29, 2013 | 11:58 AM
I've always assumed that's because the 05-09 was transitioning from the SN95 which also had a straight beltline, but increased the flare of the wheel wells in lieu of 'hips'.
Old Dec 30, 2013 | 03:32 PM
I totally agree with you Chris and feel the same way.. As the C-scoops are not just retro, but are indeed timeless and a very huge part of the Mustang's 50 year heritage as well..
Which is just another fine example why I love my current 06 GT.. As it's not just retro, but also timeless as far as I'm concerned..
