2015 Mustang Tire Pressure Monitor Sensor Tutorial Video
Former Vendor
Ford TPMS-35 Mustang Tire Pressure Monitor Sensor TPMS 2015
These are valve stem style tire pressure monitor sensor, also known as TPMS for all 2015 Mustangs. If you have aftermarket wheels on your 2015 you will need these new sensors for your TPMS to work properly, if you get your wheels and tires here at CJs we do include the proper TPMS sensors to make sure your system is working correctly. You do, however, need to reprogram your Mustang and in this video we explain how to do that.
For more TPMS components available at CJ Pony Parts check out:
Mustang Tire Pressure Sensor Components | CJ Pony Parts
For more 2015 Mustang parts available at CJ Pony Parts check out:
2015 Mustang Parts & Guide | Free shipping | CJ Pony Parts
Bill, could you clear up some muddy water for me here, did you say the Tire Pressure monitor programming tool comes programmed if I buy it though CJ Pony Parts or would I have to get it programmed at a Ford dealer if I bought it through you guys??
Not entirely accurate.
I know factually that the TPMS sensors from my 2014 Mustang worked with my 2015 Mustang TPMS system correctly. Not only does the individual tire pressures report correctly, it did not require any retraining on the 2015 Mustang. The sensors I used were Ford OEM TPMS sensors for a 2014 Mustang, so I'm not certain about any aftermarket TPMS sensors.
