What's wrong with my transmission?
#62
That you think it did is an indication of your very limited language skills.
Ford provided a very detailed response to NHTSA, as is their right and their obligation. This obviously took some time and effort.
Ford also attempted to fix the problems through about a dozen running changes to the MT82 and clutch starting in 2011. Unfortunately the changes were insufficient to totally cure the shifting problems.
Got it, Kyle?
#63
oh,there's NO corruption between auto makers and feds.one word BAILOUTS.feds are giving handouts,so why would they make them fix their ratty cars when they fail under warranty...worthless warranty I meant..kinda like health insurance
#64
Speaking of dealership behavior, my dad worked for Leith Bmw for 17 years.I went on test drives in porsches and bimmers.100-150 mph runs ,7000 rpm speed shifts and missed speed shifts...GRIND! while you think you're getting an alignment
#65
No need for the sarcasm. And insults to other members will get you on vacation here so no need for that either.
#66
As far as I'm concerned anybody here is welcome to say what's on their own mind.
I just don't want others attributing things to me that I did not say.
#67
Back on subject:
XL-18 additive made an immediate noticeable improvement. I added it a few days ago before the big freeze and drove it today at about 40 F. Better, not perfect.
It's expensive but you should try the magic juice. Make sure to shake it up as the fine print says. There's a lot of polymer-glop stuck in the bottom of the little bottle. I shook it up with some fresh fluid multiple times to get it all in the transmission.
#68
I did NOT say anything which could be construed as "Ford is bribing the NHTSA".
Got it, Kyle?
Got it, Kyle?
#69
I highly recommend trying the XL-18 magic juice. It's part of factory fill in the MY 2014s.
While 40 F is not that cold in the great scheme I'm encouraged by the improvement. At 40 F, 2nd gear was pretty much un-useable until after 3 - 4 miles of warm-up. Now it goes in 2nd, still with some nibble, right out of my driveway.
#70
Back on subject:
#71
It is hard to believe that NHTSA didn't test drive the MT-82s and found nothing wrong
with the transmissions. Customer complaints have been expressed since 2011 and Ford's
only recommendation was to address the trans viscosity. The rep at my dealership
actually suggested an MGW shifter which I ordered and it will be installed this week. I am
not happy to spend $600-$700 with the install but Ford has totally failed its customers!
#72
It is hard to believe that NHTSA didn't test drive the MT-82s and found nothing wrong with the transmissions. Customer complaints have been expressed since 2011 and Ford's only recommendation was to address the trans viscosity. The rep at my dealership actually suggested an MGW shifter which I ordered and it will be installed this week. I am not happy to spend $600-$700 with the install but Ford has totally failed its customers!
#73
Deysha
#74
Is there a TSB for the grinding of gears or replacement of the synchros? Lately, I've been getting locked out of gear. I had to make shift gears quickly to catchup to the traffic flow, but got locked out of and the car behind me almost rear ended me.
Thank you!
#75
Just a theory but has anyone checked their clutch fluid when it's cold? It is possible the fluid drops as temps drop and this is causing a pressure issue leading to not 100% disengagement.
When temps drop down here in my RSX 1st gear will be near impossible to get into. I just pump the clutch a few times to build pressure and it's fine.
That being said. A friend of mine just broke the record for 1/4 times on stock engine, clutch, AND MT-82. Check it out, it can't be that bad.....
#76
Hello Deysha,
Thank you!
Thank you!
I’m not a technician or an engineer, and I don’t have a list of the TSBs for any vehicle. Your vehicle must be fully diagnosed and the concern duplicated in order for your Ford dealership to attempt any repairs on it. With the diagnosis, they can look up any TSBs, SMS, etc. that may apply to your vehicle.
I recommend you make an appointment with your Ford Dealer as soon as possible. You can schedule one online here. Then, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate it for you if needed.
Deysha
#77
Hello Deysha, Is there a TSB for the grinding of gears or replacement of the synchros? Lately, I've been getting locked out of gear. I had to make shift gears quickly to catchup to the traffic flow, but got locked out of and the car behind me almost rear ended me. Thank you!
PonyMuscletang13
9/29/15 09:40 AM
