What the **** Is this noise!!!!
Old Sep 16, 2012 | 09:55 PM
black9D5's Avatar
So I have a 2010 gt and tonight I pulled out of my girlfriends driveway and she called me about 5 min later saying she heard a ticking noise so I pulled over into the Kroger parking lot and put my car in reverse, turned the wheels to the right and backed up and I heard a ticking noise coming from the front right tire! I have no clue what it is, it sounds like "tick...tick...tick" and the faster I back up the faster the ticking gets! Please help!!!
Old Sep 16, 2012 | 09:57 PM
jmaStang's Avatar
I'd say the first thing to do is check if there is something stuck in the tire. Have you looked?
Old Sep 17, 2012 | 06:40 AM
Rando's Avatar
Exactly what I'm thinking - or a rock/pebble. They can definitely make some noise
Old Sep 17, 2012 | 08:44 AM
HizliBullet's Avatar
It's a rock in the threads
Sounds like clicking when u drive
Old Sep 17, 2012 | 09:33 AM
jonny88's Avatar
tread*
Old Sep 17, 2012 | 08:14 PM
des63's Avatar
Had a similar noise driver front on my 2010 GT. checked every tire for rocks, nails or any other foreign matter in the tread before taking it to the dealer. They found a small amount of grease on the front wheel bearing cap. They replaced the bearing and the sound went away.
Old Sep 17, 2012 | 09:26 PM
Mirad_GT12's Avatar
Hurry and inspect the whole tire. Wouldn't want it to be a screw or nail already embedded and rolling it will just dig it deeper.
Old Sep 17, 2012 | 10:18 PM
Mickstang's Avatar
I would advise you to take the car to your dealer immediately and have him let all the air out of the tires and replace it with fresh air. Canadian air would be best, if he can get it. If imported air is unavailable, try to get air from the Ozark Mountains.
Old Sep 18, 2012 | 07:25 AM
jonny88's Avatar
Yeah, the higher the elevation the better. The air is less dense at high altitude, which causes less rotational mass.
Old Sep 18, 2012 | 08:35 AM
bones302's Avatar
I was thinking wheel bearing. but first check the treads.
Old Sep 18, 2012 | 10:38 AM
MustangGTPilot's Avatar
That is right up there with me years ago asking the line boy at an airport to go and grab a bucket of propwash! He left and finally came back and said the Manager told him they were out of it
Old Sep 18, 2012 | 12:02 PM
Kgilly's Avatar
probably those high canadian air tread rocks...
Old Sep 18, 2012 | 12:28 PM
TheReaper's Avatar
This is total BS. The air should be replaced with helium.
Old Sep 18, 2012 | 09:46 PM
Mickstang's Avatar
Helium is an entirely acceptable substitute, but most drivers are unwilling to put up with that irritating high-pitched (like Mickey Mouse on crack) shriek when they break the tires loose on warm pavement. It doesn't seem to bother the Reaper, but I find it objectionable, myself.
Old Sep 19, 2012 | 09:47 AM
JoesCat's Avatar
And with all that extra lift, you'd have to add some downforce to the body somewhere to compensate - rear spoilers are already readily available, but I don't know what off-the-shelf parts are available for the front.
Old Sep 19, 2012 | 07:44 PM
Mickstang's Avatar
And add some weight in the rear for better traction; I'd suggest bagging up all the bull$#!t we've laid down in this thread and tossing it in the trunk.
Old Sep 19, 2012 | 08:07 PM
hawkeye18's Avatar
We here in the Navy often feel that Bulkhead remover is a good solution for this sort of noise. Failing that, a few feet of gig line will fix 'er right up.
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
