Swapping Power Steering From EPAS to Hydrualic
Old Oct 16, 2024 | 11:00 PM
The_Driftstang's Avatar
I have a 2012 Ford Mustang 3.7L With a EPAS system and it has been giving me issues while drifting, from constantly turning off (losing all power steering functionality) and throwing false codes to the point where I cannot drift with it at all. I have used a Forscan tool to reset the codes on the PSCM and it will drive fine but as soon as I start driving aggressive or drifting it turns back off.
I want to swap my power steering to hydraulic. I was thinking of getting a rack and pinion setup from a 2010 4.0 Mustang as I've been told that it will fit as the S197 Chassis is compatible with gen 1 s197 part (for the most part)
I have found a few different conversion kits online but don't want to order the wrong parts, I have also been told I can use an electric power steering pump from a MR2
I don't know much about the swap and any information on it is quite hard to find as it feels like everyone is doing the opposite of what I want to do.
any information about the swap or links to part would be really helpful thank you
Old Oct 17, 2024 | 09:28 AM
05stangkc's Avatar
Welcome,
I would Advise Against it as The Deeper Down The Rabbit Hole You Go The More Issues Pop Up You Never Thought of. Unless You Find Somebody Who Has Actually Done it, And Lived With It You Do Not Want to Be The Trail Blazer Trying To Band Aid the Fall Out.
Throwing Drive Belts & Squeeling Belts are Some Issues That Come To Mind!
I like the 18" Listing Here on Rock Auto. Realize The Different Listings For Wheel Size Have To Do With Turning Radius And The Larger The Tire Size The More The Steering is Restricted So The Tires Don't Rub on Inside.
https://www.rockauto.com/en/catalog/...nd+pinion,7388
KC
The Factory Ones are PRICEY!
https://www.fordpartsgiant.com/parts....html?pnc=3504
Cheese302
Oct 4, 2006 09:31 PM
Justin
Jan 27, 2005 03:33 PM
