Rear axle whirring/rubbing noise... again...
Was just driving my '13 GT 3.31 back to my apartment when all of a sudden, I start hearing the rear axle making a whirring/rubbing noise.... again...
Sounds like one of the bearings since the noise gets louder and the frequency of the slight pitch changes gets faster with speed and disappears when stopped.
I had this issue 1300 miles ago, and my dealer took a week and a half to rebuild the diff, so I am royally pissed off this is happening again. Taking it in to have it looked at tomorrow - this will be her 6th time in a dealer service shop.
Anyone else have any similar issues?
Had my rear axle replaced on my 2012 V6 with 15,000 on it. Issue started at 2,000. It was a rotational high pitched squeal coming from the rear axle. Only went away after the rear axle was replaced, took them long enough to come to it though.
I too had a differential noise on my '12 Boss 302 that could best be described as a whirring / scraping noise. After a lot of dealership and Ford Customer Service issues I found a dealership that would fix it. They ended up replacing both axles and all bearings (axle, differential, and pinion). The noise was dramatically reduced but still there.
I had a friend with a '13 GT that had a differential noise and they replaced the entire axle assembly. The root cause was determined to be an out-of-spec differential housing. Apparently the bores for the pinion bearing weren't machined "true".
I've got a feeling that my issue will come back because the root cause wasn't addressed.
I recommend you bring it back to your Ford dealer for diagnosis. Also, please PM me with your VIN, dealer, full name, mileage, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
There is no doubt Ford has put some noisy rear axles and or gears in these new
Mustangs. I only have 1400 miles on mine and the bearing noise is far more then
any vehicle I have ever owned....even when they had high mileage. I can even
hear a "backlash" at low speeds. I might add, I have never seen an axle as rusty
as this one is............everything under the car is new and shiny but the rear axle.
It sort of shocked me when I saw it.....I am really surprised at Ford.....hope these
rears get a recall.
Tom
rears get a recall.
Tom
My 2011 V6 had to have the gear & pinion assembly, along with the bearing assembly (differential) replaced at 16740 miles and again at 32170 miles. Those were done under warranty.
Now at 59600 miles and over 5 years since purchase date, it's out of warranty and the same noise is coming back. The dealer and Ford customer service say this time it's going to be at my expense. Clearly others are having similar issues. WTH?!
(Wilwoods, BMR everything and have it rebuilt internally again just because).
what was the diagnosis. i also have a 14 mustang with a whirring or metal rubbing so
mine is not that loud but out makes a ringing scratchy sound like rough brake rotors...except its not the brakes as it didn't change sound aft all with brakes on our off. load or coasting doesn't matter either. when i reach 30 mph to 40 i hear that noise. i put on stands and removed tires. let it idle in 6th and it is easily noticeable .
Rando
Sep 30, 2015 12:28 PM
Sep 16, 2015 06:44 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
