mustang Wrench light on, no speedometer, fuel light on
Old Dec 30, 2021 | 04:22 PM
Stangproblems's Avatar
Question mustang Wrench light on, no speedometer, fuel light on
I have a 2014 Mustang 6 cylinder that randomly, while driving, the wrench light comes on coupled with the speedometer reading zero, the gas warning light on (even when full), the message "---- miles to empty" on the dash and the transmission doesn't seem to want to shift.... It will stay in the same gear that it's in when it occurs. Any ideas? A good mechanic shop couldn't figure it out. they found a water leak dripping on a wiring harness in the engine compartment and cleaned that up but it didn't solve the problem.
Old Dec 30, 2021 | 05:52 PM
Welcome! Has the charging system been checked?
Old Jan 8, 2025 | 02:03 PM
Ramirez68's Avatar
Did you find the solution? I have the same problem and I can't find what's wrong with it.
Old Jan 8, 2025 | 02:18 PM
05stangkc's Avatar
Welcome,
The Op Was a One Post One Wonder and is Unlikely To Reply.
The First Thing I Would Do is Check For Codes With a Reader Which Can Pull DTC as Well as Body Codes To Try & Narrow Down Possibilities. I would Be Looking At Sjb For Any Water Intrusion as Well. Seems To Be Par For The Course These Days For Electrical Issues on S-197 Platform.
If you Can Get Some Codes Reply With Them & I Will Post Ford Shop Manual Diag. Usually Better Info Than Just Generic Info The Reader Spits out!
This Thread on Earlier Model Can Shed Some Light if Unfamiliar With Issue.
https://themustangsource.com/forums/...26-7-a-550617/
KC
GRABOID
Jul 7, 2010 07:07 PM
blueroo64
Special Edition News and Rumor
Jan 25, 2008 03:05 PM
LordBritish
Nov 15, 2005 09:29 PM
