Mustang v6 2012 won't start - please help!!
Hello, few days ago I arrived home, parked in the garage, just like every day. In the morning I got into the car turn the key - ding ding ding ding, I pushed start and nothing happened. Only relay click. ... :-(
Everything works, all fuses seems good, electricity is everywhere. Just passenger side relay and relay in engine bay (fuse box - relay in the middle) click. Starter has electricity, battery is probably good- I tried charge it and no change. I checked fuel pump wires under back seat, I also checked all grounds.
Please, help!!!
video:
Please, help!!!
video:
Any chance the fuel pump itself died? Check for spark, if you have spark, spray some starting fluid in the intake. If it tries to run on that, you're not getting fuel and the pump has died. When the pump died in the Miata I used to own, it gave no warning. Drove to work just fine, no start when I tried to go to lunch. Checked for spark and it had it. Sprayed starting fluid and it tried to run. Replaced pump and all was well.
But the engine is not turning over. starter doesn't move= no spark = no fuel sprayed from injectors. so I can spray in intake but it will have no effect. It must be miracle
. Or ???
never mind.
I looked at it yet and I know something new.
THERE IS NO SIGNAL VOLTAGE AT STARTER WHEN PUSHING START!!!
Ground and plus is OK, but the third contact .. NOTHING.
So, what could it be??
I tried lock car for 5min and than start and also nothing.
Like Father...
I ♥ Sausage
I ♥ Sausage
If you know the battery is good, next thing I'd check is the starter. Back in the old days we'd get someone to get under the car while you keep turning the switch, when it clicks they tap the starter with a hammer at the same time to free up the possible stuck bendix.
Like Father...
I ♥ Sausage
I ♥ Sausage
I just fixed the car. It is bad starter relay. But why I didn't find it earlier??
Because both relays I tried before are also dead, so when I changed them = no effect, same situation
. So tomorrow I'm going to buy at least 5 relays or all and preventively change them :-)
