Leak! Left side of rear axle wet with fluid
Old Apr 14, 2012 | 05:39 PM
2012GTCS's Avatar
Ok, well I was under the car and realized the that the Left side (drivers side) of my rear axle was pretty soaked with fluid. The wetness goes from the pumpkin to the sway bar bracket with most of the fluid build up on the bottom of the axle. It seems it could be coming from the little nipple on the top of the axle. The nipple seems loose and wobbly when touched. Anyone know what this could possible be and why/what caused it???? The car is basically brand new. It has 2300 miles on it and has been driven in nice weather only and babied 95% of the time.
Here are some pictures. It looks wetter on the bottom in person.
Attached Thumbnails Leak! Left side of rear axle wet with fluid-image-1978477625.jpg   Leak! Left side of rear axle wet with fluid-image-2781480854.jpg   Leak! Left side of rear axle wet with fluid-image-1307572832.jpg   Leak! Left side of rear axle wet with fluid-image-435046353.jpg
Old Apr 14, 2012 | 05:44 PM
Speeddmn's Avatar
That little nipple is fine, its the vent for the axle. Now as to why you have that much fluid, i dont know. Did you just go on a long drive? Over an hour? Might have built up pressure and it puked out the vent...
Old Apr 14, 2012 | 05:51 PM
LivinTheStangLife's Avatar
Take it to a dealer it's still under warranty or at least should be. It's a vent but it shouldn't leak like that. Dealer can tell you if something is wrong with it and obviously fix it under warranty.
Old Apr 14, 2012 | 06:17 PM
Shifterboy45's Avatar
Take a look at Ford's Technical Service Bulletins:
TSB 12-2-1
Rear Drive Axle Vent -- Oil Leak -- Built on or before 01/23/2012
Old Apr 14, 2012 | 06:24 PM
2012GTCS's Avatar
How do I check out that TSB? Google?
Old Apr 14, 2012 | 06:25 PM
way2qk4u2c's Avatar
http://www.njstangers.org/forum/atta...sb12-02-01.pdf
Old Apr 14, 2012 | 06:50 PM
2012GTCS's Avatar
Boom! You guys are the best. So at least I know its somewhat normal and not actually leaking per se and she's driveable.
And yes I did go on a long drive recently with accelerating heavily once or twice.
Old Apr 14, 2012 | 08:59 PM
SD CALSPCL's Avatar
My GT/CS did the same thing last month after a 1300 mile trip at 75. I did take it to the dealer, along with the TSB. The tech looked at it, pronounced the vent defective and ordered the parts listed on the TSB. The following Monday they replaced it while I had coffee, about 45 minutes total. He also replaced the differential fluid and cleaned the axle and diff housing. So, long story short, get it in, as soon as possible. Not a big deal to repair. Worth the piece of mind.
Old Apr 15, 2012 | 10:36 PM
2012GTCS's Avatar
Deysha/FCS,
Anyway you guys can up this to my dealer? Im about to take it in for my complimentary oil change and I'd like to get this taken care of. I also seem to be getting a metal on metal sound from the rear (as if the brake pads are constantly rubbing the rotors. Sound goes away when stopped. Andddd lastly when braking lightly, I get a very loud chirping/squeaking from what seems to be the Drivers side rear when applying brakes lightly. goes away under hard braking.
Thanks!
Phew that was alot.
Old Apr 16, 2012 | 01:57 PM
FordService's Avatar
Deysha/FCS,
Thanks!
Hey 2012GTCS,
I received your PM. Make sure your appointment is to diagnose your concerns. I'll get back to you as soon as possible.
Deysha
Old Apr 16, 2012 | 02:09 PM
Thamac15's Avatar
Looking at those pics of a rusty axle makes me happy I painted mine when I took her home.
Old Apr 16, 2012 | 08:35 PM
2012GTCS's Avatar
Originally Posted by FordCustomerService
Hey 2012GTCS,
Deysha
Deysha, i am going to call tomorrow and make an appt for wed or thursday of this week. Thanks again.
Old Apr 17, 2012 | 09:37 AM
Thanks, 2012GTCS. Will you please send me another PM with your VIN, dealer, mileage, and best daytime number?
Deysha
Old Apr 17, 2012 | 04:32 PM
2012GTCS's Avatar
on its way! thanks
Old Apr 22, 2012 | 07:25 AM
TwistedKarma's Avatar
The left side of my rear axle was leaking as well. The dealership I brought it to ordered the vent and repaired it in a day. Apparently it's not a big deal and it's a known issue with vehicles that fall under a certain production date, that is what I was told. When I asked if I could take my car for the night they insisted it not be driven.
Old Mar 2, 2020 | 11:32 AM
actormike's Avatar
I made a video that shows how to change the vent valve for those who need it-
apial
Sep 6, 2015 10:40 AM
glo106
Aug 11, 2015 08:29 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
