High Speed Rear Axle Whine
Old Jun 29, 2013 | 07:43 PM
wentw1tj's Avatar
my 2014 "Track Pack car" has some gear wine Whine around 75 mph. if you go over 75mph to like 85 or 95 it disappears, is this normal. The car runs outstanding in every way. I have 1700 miles on it now, it has done this since it was new.
Old Jun 30, 2013 | 06:29 AM
elkk's Avatar
I have also noticed slight gear wine in 6th gear mostly when letting off the accelerator. Not terrible but it is there. Like most, I have happy with the car and would hate to have the dealer screw with it for what I consider a minor issue. I don't consider it normal or abnormal, just the way it is. There is the possibility having it serviced could result in even more issues created by the dealer trying eliminate the wine. If it gets worse I will have them look at it, until then I will listen to the radio and exhaust note.
Old Jun 30, 2013 | 10:35 AM
houtex's Avatar
That gear wine tastes so bad. They can never get the petroleum taste out of it, and I also understand it might give you intestinal disorders and possibly cancer. It really doesn't pair with anything else. And seriously, this stuff and a cigar? You might call it an 'explosive' coupling, but you might also be literally blown away by the experiment.
I don't recommend anyone actually buy it and consume it, and it's just awful it's on the shelves at all, even if it's sorta rare to find it at...
What?... What do you mean... Oh! Y'all mean *'whine'*! My bad, sorry, ignore me.
/Actually... I like the idea of that being a label... Wine for gearheads...
//Aaand, looks like I could get it too.
///In all seriousness, you will have some gear whine, as there's no real way to eliminate all of it, harmonics and such, but you really should compare it to another Mustang of same year and configuration. Ask a service writer to arrange for that to happen, they might can fix ya up to see. And what Bill said, might make things worse if you muck with it.
Old Jun 30, 2013 | 12:15 PM
racksteris's Avatar
no easy fix, The gears will need to be replace and if there not experienced in gears, they can make it worse,,,,,,
Old Jun 30, 2013 | 12:51 PM
muscledom's Avatar
Dude when you have higher ratios you're gonna hear some rear end noise. If it isn't bad I wouldn't sweat it. But I guess since its brand new you ought to have it checked out.
Old Jul 1, 2013 | 07:48 AM
mfc133's Avatar
Originally Posted by wentw1tj
my 2014 "Track Pack car" has some gear wine around 75 mph. if you go over 75mph to like 85 or 95 it disappears, is this normal. The car runs outstanding in every way. I have 1700 miles on it now, it has done this since it was new.
My '13 track pack has this too. You can hear it at highway speeds when you transition on/off the gas. I thought about taking it in, but decided it's not worth the hassle. It's barely audible right now, so dealer would probably just say it's normal/expected.
Old Jul 1, 2013 | 12:02 PM
FordService's Avatar
Hi guys,
I recommend getting them checked out at your dealer as soon as possible. Then, PM me with your VIN, dealer, full name, mileage, and best daytime number so I can escalate this to the customer service manager for your area.
Deysha
Old Jul 1, 2013 | 12:09 PM
TheReaper's Avatar
Put some miles on and it will go away.
Old Jul 2, 2013 | 08:12 AM
Ltngdrvr's Avatar
Late to this thread but this was almost exactly my thoughts when I saw the title!!!
SHAME ON US SMARTASSES!!!
Old Jul 2, 2013 | 08:45 AM
99mstng's Avatar
Had my gears replaced by the dealer twice ... 3.73s. It's still there. Not horrible but my 99 with an 8.8 and 3.55s is silent. I'll live with it and try some different fluid in a year or so maybe that will help, who knows.
Old Jul 2, 2013 | 09:04 AM
Brandon302's Avatar
Sounds like a non-issue, mine does it, my dad's Fox does it, friends 03 Cobra does it. Just something you'll have to get used to.
Old Jan 4, 2025 | 04:32 PM
05stangkc's Avatar
11 Years Later I Will Fix The Title Typo Problem For The WHINERS!
KC
Old Jan 4, 2025 | 05:06 PM
m05fastbackGT's Avatar
it appears somebody has way too much time on their hands...
Old Jan 4, 2025 | 06:25 PM
05stangkc's Avatar
We Have Years of Disorganization & Errors. When I Stumble on One I Fix It. Hint Hint!
KC
Old Jan 5, 2025 | 02:52 PM
Yes, I know... I'm also just as guilty... Hint-Hint!
dstathis
Jul 7, 2017 07:23 PM
kn7671
Apr 1, 2015 05:04 PM
blairnr67
Mar 15, 2013 11:32 AM
rmurer
Nov 13, 2012 10:04 PM
lp9820
Aug 2, 2010 08:51 AM
