Help With Service Advance Trac! 2013 Mustang!
Old Jul 3, 2025 | 05:22 PM
MoTiVeZ69's Avatar
Service advancetrac warning came up and i cant seem to figure out whats causing it. 2013 v6 mustang
Updated Your Title For Better Search Results & Moving You to Repair & Service Section!
No Harm No Foul!
KC
ADMIN
Old Jul 3, 2025 | 05:42 PM
m05fastbackGT's Avatar
Do you have access to a hand-held scanner? If not, your local Advance Auto Stores will allow you to connect one of their scanners free of charge... Once the scanner provides the code, you'll know exactly what the advance trac warning is... In the meantime, welcome aboard and best of luck...
Old Jul 3, 2025 | 05:43 PM
MoTiVeZ69's Avatar
Appreciate it glad to be here
Old Jul 3, 2025 | 06:09 PM
05stangkc's Avatar
Welcome!
Yes Get Some Codes, We Have The Ford Diag Pdf's If You Supply Number Codes. The Generic Readers are Great For getting The Number But Description Can Vary! Ford Shop Manual Pdf's Sometimes Provide a Step By Step Although May Need Special Equipment!
DTC Section!
https://themustangsource.com/forums/f804/s-197-2010-2014-obd-shop-manual-dtc-code-info-550475
Here is a Weird One on That Issue! Worth A Look At Wiring!
https://themustangsource.com/forums/...solved-546958/
Search on Threads ADVANCED Just Put Advance Trac in Left Box on Title Search!
https://themustangsource.com/forums/search.php
KC Admin
Old Jul 4, 2025 | 05:03 AM
Bert's Avatar
check out this thread: https://themustangsource.com/forums/...solved-546958/
I can't say for sure that this is your issue, but definitely worth checking -- this problem drove me nuts for years until I finally figured it out
DD GT3 RD
2012-2013 BOSS 302
16
Aug 28, 2022 12:15 AM
iiaces
1994-2004 V-6
Oct 8, 2013 09:22 AM
Onegr8stang
Mar 13, 2013 03:49 PM
focusharley
Dec 5, 2006 04:59 PM
