Fan squeal after car is shut off
Old Nov 7, 2012 | 01:01 PM
azstang12's Avatar
Hi everyone,
I have a 2012 Mustang GT and I wanted to see if anyone else had a similar noise on their car. When I shut the car off and the cooling fan is spinning down and coming to a stop, as it comes to a stop it squeals a bit. It's not terribly loud, but is a bit annoying and makes the car sound like an old POS. I have an apt with the dealer tomorrow to have them look at it, but it doesn't make the noise all the time as it seems to be temperature related. I talked to the service manager and he's already leaning towards the "that's normal" stance, but he wants to hear it. I was just wondering if anyone else's does the same thing. Thanks
Kevin
Old Nov 7, 2012 | 01:02 PM
11SHELBYGT500's Avatar
Originally Posted by azstang12
Hi everyone,
Kevin
WD-40
Old Nov 7, 2012 | 01:05 PM
azstang12's Avatar
WD-40
I'll be doing that if the dealer doesn't want to do anything Although I shouldn't have to be using WD-40 on an electric fan that's a year old....
Old Nov 7, 2012 | 01:09 PM
True, but its probably just an electric fan with dry bearings. Have you looked to see if it might be rubbing the shroud on some way?
Old Nov 7, 2012 | 01:11 PM
azstang12's Avatar
You're right I'm pretty sure that's all it is. It doesn't appear to be rubbing the shroud at all. The problem is getting in there to get the WD-40 applied. I'm pretty sure I can get to it fairly well if I remove the air tube from the air box to the throttle body.
Old Nov 7, 2012 | 02:40 PM
Bucko's Avatar
It's not "normal". I'd insist on a replacement, especially if it's still carying a warranty. You should be covered with both the 36/36, and then the 50K engine/drive train kicks in. I'd think the fan would fall under that as well?
Old Nov 7, 2012 | 03:07 PM
azstang12's Avatar
Thanks Bucko, I'm going to doing that tomorrow, it's still WELL under the warranty, plus I have an extended. I would imagine the squeal will only get worse over time....
Old Nov 8, 2012 | 05:36 AM
Bucko's Avatar
Agreed. Too nice of a car to squeak!
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Coyote5-0
Aug 2, 2015 08:38 AM
roushcollection
Jul 28, 2015 02:08 PM
valanahara
Jul 22, 2015 05:13 PM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
