Dash door light warning
Old May 20, 2024 | 08:43 PM
Macgould's Avatar
Mustang Gt 5.0 Member The Detailing Drummer
Today I noticed the dash light indicating either the door or trunk was open. I drive a convertible so got out checked the two doors by opening and closing and same with the trunk. The light never went out until turning the car off. Is that a fuse issue?
Old May 20, 2024 | 09:43 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Wouldn't think a fuse. Most likely a switch on one of the doors or trunk.
Old May 21, 2024 | 02:50 AM
05stangkc's Avatar
Yep Likely a Switch! BUT JUST A GUESS!
I Think a Code Reader That Can Read {BODY CODES} Would Pin Point it. Can't Recall For Sure?
Gonna Move You To Repair & Service Issues!
Usually The Most Used Access Point. Drivers Door Best Guess!
Here is The Ford Switch I Do Believe For Drivers Side!
https://www.fordpartsgiant.com/parts...tra2=&filter=()
The Goofy Thing Is The 2012 Shop Manual Just Omits The Switch Install Part So You Need To Look at Earlier Car PDF. Go Figure.
https://iihs.net/fsm/?d=466&f=Door%20Ajar%20Switch.pdf
KC
A Hail Mary Pass With Some Contact Cleaner Sprayed Downward May Clean Switch Enough To Get Light Out! Worth a Try. POINTING MORE STRAIGHT DOWNWARD! Could Do Both Doors!
The X is About Where Switch Would Be Inside Door!
Number 3 is Luggage Lid Switch! Again This is Earlier Car Maybe Different on 2012 Does Not Show Switch on 2012 Shop Manual!
File Type: pdf
Old May 21, 2024 | 11:31 AM
m05fastbackGT's Avatar
My guess would also be a switch as well..
Old May 23, 2024 | 12:19 PM
Macgould's Avatar
It's been pouring down rain here, a lot so today between storms finally got to try out the ideas you guys submitted. It's fixed. Definitely not the fuse, sprayed into the area recommended and tried the doors. Light out, Thanks everyone for the advise.
Old May 23, 2024 | 02:39 PM
05stangkc's Avatar
Sometimes A Little Cleaning Brings Desired Results! After So Many Years The Original Lube Will Turn To Gum Like Consistency!
KC
pedroguaraldi
Oct 26, 2024 10:55 AM
Blake Smith
Sep 27, 2019 07:40 AM
85Fox
Dec 15, 2011 10:26 PM
firejay
Oct 4, 2006 09:27 PM
