Cracked Rotor?!
Old Jul 23, 2014 | 08:49 AM
05PRMTX's Avatar
Cracked Rotor?!
Noticed this last night when I got home. Is it common for Rotors to crack like this?! Its part of the RTR package, which the dealer said was installed there by Ford in San Antonio a couple years ago and would still be under warranty. Would something like this be covered? I know this isn't something I did
Old Jul 23, 2014 | 08:51 AM
rmurer's Avatar
wow something crazy must have been going on for a rotor to crack... i mean i would think so atleast cause i've never heard of one cracking before.
Old Jul 23, 2014 | 08:54 AM
05PRMTX's Avatar
http://imgur.com/qyoxVsP
Not the best pic, I'll try and get a better one later
Old Jul 23, 2014 | 08:57 AM
05PRMTX's Avatar
Right?! It appears to be fairly shallow and goes through one of the cross driled holes, but how does that even happen? I'm not a crazy driver. I've just been going too and from work lately
Old Jul 23, 2014 | 11:36 AM
FordService's Avatar
I recommend you speak to your service manager about this, 05PRMTX. He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
You can schedule an appointment online here.
Deysha
Old Jul 23, 2014 | 11:45 AM
Joeywhat's Avatar
Not entirely uncommon on drilled rotors...
Old Jul 23, 2014 | 12:01 PM
typesredline's Avatar
Just about to say this. I always went slotted for this reason.
Old Jul 23, 2014 | 12:10 PM
05PRMTX's Avatar
It is through one of the drilled holes so I guess that makes sense. I've just never seen a crack on a rotor before. It isn't very big, but is this something I need to address immediately?
Old Jul 23, 2014 | 12:23 PM
Joeywhat's Avatar
Yes, it should be replaced ASAP. Your rotor is compromised structurally, and it could come apart at speed which would not be enjoyable for you or anyone around you.
Get it fixed.
Old Jul 23, 2014 | 12:30 PM
Usually from heat from track usage right?
Old Jul 23, 2014 | 12:34 PM
Joeywhat's Avatar
I've seen cheap ones crack from just street usage.
Old Jul 23, 2014 | 12:46 PM
05PRMTX's Avatar
This one is supposed to be from Ford.....
Old Jul 23, 2014 | 12:48 PM
05PRMTX's Avatar
Get it fixed.
Right, I kinda figured. I scheduled an appointment for tomorrow morning
Old Jul 23, 2014 | 12:56 PM
KushBandit's Avatar
Ditto. I recommend quality slotted rotors for this very reason. Cheap drilled rotors can crack under street use and will eventually crack under hard track braking.
Old Jul 23, 2014 | 01:02 PM
Joeywhat's Avatar
I highly doubt they are Ford OEM parts. Dealer installed does not equal manufacturer installed.
Old Jul 23, 2014 | 01:14 PM
05PRMTX's Avatar
It appears these are what came with the package.
http://www.carid.com/2011-ford-musta..._CgaAqvQ8P8HAQ
Old Jul 23, 2014 | 11:23 PM
jc46002003's Avatar
Heat will cause that. They can cool down pretty quickly after a light pressure but long duration apply, they can crack if they're not manufactured just right.
What I see a lot of are people using their breaks in situations they don't need to when simply letting the foot off the gas will let the car do the same job by itself. Not saying you do that but ****, people around here eat breaks like there's no tomorrow. Rolling stops and just generally hitting the breaks in the middle of their cruise for no apparent reason ( there's no1 around and they aren't about to turn or stop, they just hit the breaks in the middle of the road ). I see this every single day.
Old Jul 24, 2014 | 07:17 AM
05PRMTX's Avatar
I hear you there. People love their brakes here in Houston. Like you said, they just hit them for no reason whatsoever. A lot of times forcing me to use mine when I otherwise wouldn't. Half the people here should not have a drivers licence.....
Old Jul 24, 2014 | 09:14 AM
Think that's everywhere lol.
TerryD
Sep 28, 2015 11:48 AM
bconboy
Sep 18, 2015 08:18 AM
Sep 16, 2015 06:44 PM
bconboy
Sep 10, 2015 02:31 PM
