3rd gear lockout high rpm
Old Oct 16, 2024 | 08:17 PM
youknow_rj's Avatar
I have a 2014 mustang gt, the car revs out to 8k and it shifts like butter in every gear except third (no grind). I have done everything hydraulic and inside the bell house. Twin disk rst, brand new oem TOB/slave cylinder, mgw race spec shifter, BG snycro shift fluid, steal braided clutch line, brand new clutch master cylinder (has been vacuum bleed) the trans has about 80k on it, I have no idea what I’m missing could anyone have a clue what’s going on it seems I’ve done everything.
Old Oct 16, 2024 | 08:54 PM
05stangkc's Avatar
Looks Like All is Left is Internal!
Here is Diag Out of Shop Manual!
  • Transmission will not shift into one gear — all others OK
  • Manual shift linkage
  • REPAIR or INSTALL new components as necessary.
  • Backup switch ball
  • If REVERSE is the problem, CHECK reverse lamp switch for ball frozen in extended position.
  • Internal components
  • INSPECT the shift rail and fork system, synchronizer system and the gear clutch teeth for restricted travel. REPAIR or INSTALL new components as necessary.
KC
Cyphensypher
Jan 27, 2023 09:59 PM
trackpack13gt
Aug 8, 2015 11:23 AM
airoscar
Jul 12, 2012 11:07 AM
Chubbs88
1994-2004 V-8
Jun 5, 2012 04:33 PM
deshawnb50
May 28, 2011 09:27 AM
