2014 Mustang P2112 Code
Old Dec 17, 2024 | 02:06 AM
S197_V8's Avatar
Exclamation 2014 Mustang P2112 Code
Hey guys, a little back story on my car. I did an engine swap on my car, went from 3.7 to 5.0. I brought a 5.0 Manual donor from somebody in town, swapped everything over onto my 3.7 at the time. I purchased an automatic transmission kit from eBay to go into my car. I swapped everything I could think of:
  • Suspension setup (Shocks n Struts & Springs)
  • Driveshaft (Came with Auto Trans Kit)
  • Engine
  • Wiring (Engine Harness and Transmission Harness)
  • Rear Axle Setup (Took it from 5.0 Donor)
  • 5.0 Donor Key Setup (Cylinder, Transceiver, Original Key)
  • Cluster
Now, I recently sent over the Automatic ECU sent off to Garrett Tuning to get a PATs delete done. Got it back, car cranks up but it acts like it want to die while on idle. I press on the gas pedal but get no response at all. Check for code, "P2112 - Throttle Actuator Control System Stuck Closed". So I purchase a new Throttle Body from eBay to test it out and it still doesn't work. No response to the pedal and the code stays the same. Is there anything I can do before I send it to Ford to get it fixed.
Old Dec 17, 2024 | 03:35 PM
m05fastbackGT's Avatar
I recommend having Garrett Tuning re-check your ECM and bring them up to speed with your "P2112- Throttle Actuator Control System Codes... More than likely the code is related to a tuning issue...
In the meantime, welcome aboard...
Old Dec 17, 2024 | 03:55 PM
Bert's Avatar
welcome to the forum
I second m05's thought/suggestion -- first guess would be a tune issue
Dagriff1998
May 23, 2023 08:16 AM
Derick423
Mar 10, 2020 10:08 PM
05PRMTX
Apr 6, 2015 09:57 PM
big429block
Jul 21, 2012 05:37 PM
Thomas S
Jul 2, 2010 08:38 PM
