2011 Mustang GT Passenger Power Window Problems
Old Jun 6, 2013 | 08:04 AM
Jonathanmustang's Avatar
The problem is that the passenger power window will only work properly from the passenger side switch. I am able to lower the window with my driver’s side switch, however, when I try to pick the window back up, the window continues to lower no matter if I move the drivers switch up or down. Has this problem happened to anyone else? If so, how do I fix this issue?
Thanks your your help!
Old Jun 7, 2013 | 11:39 AM
AzPete's Avatar
Use the warranty if you still have it. Otherwise, pull the door panal and check the drivers side switch. Might be just a bad switch.
Old Jun 7, 2013 | 12:26 PM
wheelman's Avatar
Originally Posted by AzPete
pull the door penal
That sounds harsh
RRRoamer
Jan 19, 2017 05:27 PM
Warrior316
Jul 28, 2015 11:05 AM
TrueBlue302
Jul 23, 2015 06:13 AM
MRGTX
Jul 21, 2015 02:08 PM
Kgilly
Jul 9, 2015 01:47 PM
