2011 Gt having issues with Pats /Found Issue Water Intrusion in SJB
Old Sep 25, 2023 | 09:24 PM
jentvanover47's Avatar
I have a 2011 gt and been having issues the last couple of days with pats. It will start up first thing but when I get to where I'm going and shut it off, it will not start back (flashing theft light). I can let it sit for about 20 minutes or so and it will start or the pats light quits flashing. I noticed tonight that I can unhook the battery go back in the car and put key in, put it to the start position, then go hook the battery back up, go back in car and it will start but soon as I turn it off it won't start back up(flashing theft light). I done this a total of five times in a row and it done this every time. I have tried both keys that I have and one of them is a brand new ford key. The dtc's I have are B10D7-87, B10D7-8F, and B10D5-13. I also have tire pressure sensor fault but I just had brand new wheels and tires put on a couple of days ago, don't know if this has anything to do with what is going on or not. Any help will be greatly appreciated thank you!
Old Sep 26, 2023 | 06:50 AM
05stangkc's Avatar
@jentvanover47
Here Are Codes & Shop Manual Section !
Looking Like Tranciever So Far!
I Would Advise Getting the TPMS Sensors Out of The Mix! Won't Hurt!
Mgb,
KC
File Type: pdf
Old Sep 26, 2023 | 07:48 AM
@jentvanover47
Mgb,
KC
Thank you sir, I'll give it a look
Old Sep 26, 2023 | 07:54 AM
05stangkc's Avatar
How Did You Get Body You Codes Listed?? What Device??
Also Did Start Issue Happen Immediately after Tire Install??
Mgb,
KC
Old Sep 26, 2023 | 08:05 AM
I got the Codes from Snap-on code reader.
And no it didn't happen immediately.
Old Sep 26, 2023 | 08:09 AM
SJB connector
SJB module
I found seal gone on windshield
Old Sep 26, 2023 | 08:12 AM
I pulled out the SJB and found this, could this be causing issues? Can I clean this and reinstall it? What to use if I clean it (electronic contact cleaner)?
Old Sep 26, 2023 | 08:19 AM
05stangkc's Avatar
Ok Looks Like Water Intrusion! Pretty Common. Clean Well With Electrical Contact Cleaner and Let Dry Well. Hope For The Best! Good Time To Check Cowl Drains as Well! We Have Seen Rats Chew The Wires as Well For Some of These Gremlins!
I Like This Cleaner!
Amazon Amazon
Mgb,
KC
Old Sep 26, 2023 | 11:40 AM
05stangkc's Avatar
Please Let Us Know How it Turns Out!
Mgb,
KC
Old Sep 26, 2023 | 07:29 PM
I got the sjb pulled out and cleaned it with some contact cleaner and put some dielectric grease on it. I have drove all over the place today and never had any issues with it. I really think this took care of the issues. I'm going to take it tomorrow to hook scanner up and erase the codes. Thank you for all your help!!
Old Sep 26, 2023 | 07:37 PM
05stangkc's Avatar
2011 Gt having issues with Pats / Water Intrusion in SJB
Outstanding! Glad To Hear!
Just Make Sure and Check For Water Leaks So It Don't Happen Again! I Just Got Through Putting Stickies on A Bunch of Water Leak Threads! Very Popular! Too Popular Sad To Say!
A Ton in the 05-09 Repair Section! And I am Still Searching For More to Have in One Place Per Year Spread!
Again Very good To hear and Your Thread Will Help the Next Guy For Sure! Closure is Great as Some Will Come in For Help and Disappear! Appreciate the Follow Up Very Much!
{Updated Title To Help Others With Issue With Topic Search!}
Mgb,
KC
Old Sep 26, 2023 | 07:45 PM
I forgot to ask you but can you buy just the weather stripping that goes to the Cowl Vent Panel or do you have to replace the whole thing? I seem to not find anything when I was looking.
Old Sep 26, 2023 | 07:50 PM
05stangkc's Avatar
The Strip is More of a Leaf Seal Than a Water Seal. It Is Not Available By itself But Comes With New Cowl. But I Think Some Bulk Door Edge Moulding Would Work Well. Let Me See if I Can Find What I am Talking About. Here is Cowls Though!
https://www.fordpartsgiant.com/parts...?pnc=%3C018A16
This Stuff is Cheap and Should Work Well if You Match to What You Have.
https://www.ebay.com/itm/15493897856...CABEgLSlPD_BwE
You Can Also Get the Packaged Door Edge Gaurds Which Have Adhesive inside at the Local Parts Houses Fairly Cheap! Look Like Above But Have a Glue Inside.
Mgb,
KC
Old Sep 26, 2023 | 07:58 PM
Ok thanks man for the info, I might go tomorrow to Lowes and see if they have something similar to what you showed and see if that works. I can't believe them panels are over 300 dollars for both Lol
Old Sep 26, 2023 | 08:05 PM
05stangkc's Avatar
Worth a Little Effort! I Used to get Them at the Local Orielly's I Found a Box But I Guess They are So Old Even the Barcode Won't Come Up! Time Flies!
Good Luck!
If You Find Something Good Do A Post with a Part Number So The Next Guy Don't Have to Buy Those Spendy Cowls!
Mgb,
KC
Old Sep 26, 2023 | 08:07 PM
Ok appreciate it man for all your help!!
JT_Kwik
Nov 29, 2022 01:45 PM
mwt31
Jun 30, 2021 10:50 AM
csmustang97
Jul 18, 2016 01:57 AM
mdbp8
Sep 3, 2005 01:59 PM
