2011 gt engine light
Old Jun 23, 2012 | 10:23 PM
08ljensen's Avatar
So my engine light came on a month ago and i used my scanner and it told me that my motor was running too lean. It gave me code p0174. I cleared it thinking it couldve been an error or fluke. A week ago it came on again an the scanner told me the same code. This time i didnt clear it. However a day later the engine light turned off by itself. Should i take it to ford? Should i be concerned? The powertrain warranty is still intact, but probably wont cover it because the issue isnt with lubricated parts... I think. My only mod is a cai by c&l.
Old Jun 23, 2012 | 10:26 PM
AlsCobra's Avatar
A Man Just Needs Some....
CAI without a tune will be you problem man. Is you car tuned also? If not a tuner should take care of if.
Old Jun 24, 2012 | 06:59 AM
kylerohde's Avatar
If all you've done is put an intake on but not a tune, the intake shouldn't be making the engine run lean. I'd definitely go to the dealer, as a blown motor is going to cost far more than whatever problem you have now.
Old Jun 24, 2012 | 07:03 AM
Gster's Avatar
If you put the CAI on yourself make sure everything is tight with no leaks. Leaks will cause this code.
Ecostang
Nov 3, 2022 08:50 PM
Good Times
Aug 29, 2015 10:18 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
