171 and 174 codes
Old Jul 28, 2013 | 08:30 PM
kanjc's Avatar
171 and 174 codes
I have a stock 2010 mustang with the V6, yesterday she was running great all day and then out of nowhere started surging and then stalled and died. I managed to make it home and check the codes and it gave me 171,174,2195,2197 when I cleared everything and tried to take up to the gas station to put some super in it I got a 795 code. it wont idle but when I was making it home I had it nearly floored and she was going great but once I let off she stalled and died again. I am at a loss here, if this car was my 76 I would know what to do but....
in addition:
Just changed the fuel filter now I am getting 300,304,305,306 cylinder misfires
Old Jul 29, 2013 | 05:57 AM
Bucko's Avatar
Type each code in the Google search window, and start reading up on the threads it will provide.
The later codes indicate a misfire for cylinders 4, 5, and 6 (304,305,and 306; 300 is a randum misfire. Here's a link from a google search that shows possible solutions to misfires:
http://troubleshootmyvehicle.com/for...isfire-codes-1
Here's a link to many of the Mustang trouble code definitions:
http://www.latemodelrestoration.com/...-SVT-Lightning
I'd suspect the coilpack connector as a possibility, or it's wiring with the second set of codes you got. Check it's connector. Remove the coil pack and inspect it for cracks. Here's what it looks like:
It's a pricy part at $159.00, so be sure it's bad before replacing it. There are other possibilities for misfires.
Did anything get repaired under the hood recently? Maybe a wiring connector got damaged? A gound wire?
Old Jul 29, 2013 | 08:47 AM
FordService's Avatar
in addition:
Hello kanjc,
Welcome to the forum! My name is Deysha with Ford Service. I recommend having your vehicle checked out at your Ford Dealer and speaking to your Service Manager about this. He/she is in the best position to look into this for you. He/she can check into any warranty, assistance, recalls, or Customer Satisfaction Programs that may apply to your vehicle. Let me know the outcome.
Deysha
Old Jul 29, 2013 | 01:11 PM
kanjc's Avatar
I replaced it ( the coil pack ) and there was no change, I am getting ready to have it towed to ford I will let you all know what they find.
Old Jul 29, 2013 | 01:17 PM
Bucko's Avatar
Did you inspect it prior to replacing it (coil pack)? Not good to hear you bought one and gambled with it. The other link I listed also provideds other reasons for mis-fires. Hopefully it is not a costly repair, although labor is about 90 bucks an hour, then there's parts.
Old Jul 31, 2013 | 07:35 PM
kanjc's Avatar
So it turns out to be several issues one that was the main culprit and a couple small ones that contributed to it. MAF was the biggie, but they also replaced plugs and wires. I had them do the fuel injectors as well as some regular maint items ( oil and tranny service) all in all it cost me $1400 plus a rental car. Ouch!
Old Aug 1, 2013 | 05:31 AM
Bucko's Avatar
I went back and checked the link to troubleshooting mis-fires, and it never listed the MAF as a suspect item for misfires.
Plugs, plug wires, the ignition module, and injectors were all suspect. What was the part cost for the MAF?
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
