Where to connect the ground wire for an amp in the rear
Old Jun 7, 2014 | 07:47 AM
14stangGT's Avatar
I got everything taken apart and now I am lookg for a place to connect the ground wire in the rear of the car.
Old Jun 7, 2014 | 09:25 AM
houtex's Avatar
Any hard bolt location will do. The entire body is a ground, so a good metal-to-metal connection is going to suffice. Find a good, convenient bolt that is usable for a ring terminal to go around, sand the paint off the body and the underside of the bolt so there's metal to metal (to metal, in this case) and reattach the bolt.
I'd also then spray some paint on that when it's done to protect it from future rust, or possibly goop it up with some dielectric grease, one of the two.
Hope that helps!
Old Jun 8, 2014 | 08:36 AM
apial's Avatar
You should have prepared ground connectors behind the trunk back trim. They already have a thread, just remove the paint a little bit, take a matching screw and mounting the cable there.
I marked the connectors for you on the attached picture.
Attached Thumbnails Where to connect the ground wire for an amp in the rear-cimg1021.jpg
Old Jun 8, 2014 | 05:19 PM
houtex's Avatar
Oooh. I just learnt somefin new! I'm one of the 10,000 today!
And now, evil plans will take place.
/Like the cut wires there...
Old Aug 11, 2014 | 04:25 PM
mustang5o's Avatar
They have a thread but what about a bolt for it? I'm in the same boat as the OP. I just need to connect the ground then a test hit of the sub. If I need a bolt for those prepared spots, what size is it?
Old Aug 11, 2014 | 06:19 PM
mustang5o's Avatar
I found a bolt right next to that area that looked like grounds because they are just bolted to the metal of the body. I'm going to try that. How do you test if that's a good ground?
Fords4Ever
Oct 30, 2015 09:07 PM
seaclam
Sep 25, 2015 01:29 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
Steve@CJPP
Sep 3, 2015 10:43 AM
