STARTED MY IPAD MINI INSTALL PROJECT
FINNISHED MY IPAD MINI INSTALL PROJECT
I have a '13 GT with Shaker 500. Already changed out all the speakers and added a sub. Now I'm going to disable the factory audio and add a single din head unit, an IPad Mini slider mount and keep the factory climate controls. The head unit will go as high as possible. Then the IPad Mini right below it. There are some great Raxion Nav install instructions on American Muscle. They show you how to move the climate module (which sits right behind the SYNC screen) up and out of the way. I then bent the climate module brackets up and to the sides. After removing the cd/audio unit, the whole area behind the face plate is wide open. I am fabricating a face plate myself (first time) out of ABS. So I am losing SYNC. Not much of loss in my opinion.
The climate/audio controls are incorporated on a single board as far as I can see. So once I removed SYNC and the audio unit, I plugged the controls back in. The climate still works perfectly. So far so good.
The reason the IPad mini is going in below the head unit is because the factory/audio contrrols will be behind it, sticking out the bottom with only the climate controls showing. I know it will be a challenge to make it look right. I have found patience and a little elbow grease goes a long way. I just need to find a paint to match the console.
Why am I doing it this way?
- So many people have complained about the Metra and Scosche kits that they are not an option for me. So I am keeping the factory climate controls.
- The ADS iData Maestro kit is too expensive. Also, my IPad mini will sit up higher than the double din screen does using the ADS kit.
- My son gave me an almost new head unit to use.
- My cost will be the IPad Mini, $219 at Walmart, and the fabricating the mount, about $100.
- I love DIY projects!
Hey Cali - This is awesome and I'm subd as well! Let me know if there's anything we can help out with and if you don't have our Forums Discount Code shoot me a PM! I can see you just rolled onto your 50th post!
Alex
Alex
Have you considered one of the Musicar Northwest Ipad mini holders?
I installed Sync into this base 13. Use the ipad mini with the Musicar Northwest ipad holder that I wrapped in carbon fiber to match our radio bezel/console. I also got a wifi OBDII scanner plugged into the OBDII port so this ipad mini can run the DashCommand app WIFI or I can use Sync to connect to it to run music. Right now found the best setup is use the iphone to connect via USB to sync for calls/music and wifi the ipad.
Best of all, it looks great and in about 2 seconds I can pop out the ipad or the entire holder and you can not tell that it was even there. This pic is of the holder just sitting in place. With the magnets, it is held higher and now I have finished the clear coats for the finish on the holder.
Sub'ed. Im in the middle of this right now. But my plan is to possibly create a overhead console to mount the ac controls in. I've been so busy working on other mods that this project has fallen to the wayside. But the whole car is going in for paint/bodywork in the next week so I should have plenty of time to work on it a little more.
Overhead roof controls.
http://www.3spro.com/mustang/
I'm not sure if you've seen this before but just thought I would throw this your way:
The bezel is really nice now. In truth I wish there was a way to just use the IPAD in the bezzel and have a way to control the havoc from it.
I am surprised that nobody has come up with it as yet. IDATA-Link has it, I can control my Havoc from the Kenwood deck. I'm sure it could be done by using a Ipad...
But then again, you are doing this for yourself.
I understand that you might not want someone else to have the same thing as you.
Well, if you get something completed and you think about maybe making a kit, or a mold, maybe some members might be interested in buying it?
subscribed. Looks like a fun winter project.
I have had the scosche kit in for 3+ years now and am very happy with it. once you get used to having the head unit down low, it's fine. not sure what the complaints were other than the battery drain issue which was easily solved with a firmware update.
I wanted to try this IPda ideal, but did not want to do the whole control on the roof thing. Also yes it is pretty expensive. 1500, but it is set up nicely. I would like just to do the ipad...but then you would not have the havoc controls.
I know a while back I was trying a android solution, and someone had figured how to use the havoc controls on a android base system...I wonder if the same could be done for a Apple ? Then you could setup a similar system to the one that has it on the roof, but minus that part.
The dock they use is quite nice as it still keeps the info screen. That would be ideal.
