Replace lighter socket with data USB port
Old Nov 15, 2025 | 12:07 PM
Augy's Avatar
Has anyone replaced the lighter socket on the dash (above the radio) with a USB port that can be used with the radio (like the one in the center console)? I hate having a long usb cord snaking from the center console up to where I have my phone mounted above the radio. I believe there is a micro-USB port on the Sync module behind the glove box (at least on Nav version) which could be used, as well. The goal would be to have a very short USB cable coming out of the dash where the factory lighter socket is which is essentially right behind my phone mount. I searched but only came up with older threads which referenced that extra USB port in the Sync module.
Old Nov 21, 2025 | 03:00 PM
shaneyusa's Avatar
No I have not seen that done, but sounds like a worthy project. Search this site, and maybe take a run at Google.
I would guess it would not be a tough project to extend the port from the console to the lighter/DC port in the dash, but not sure about finding or adapting a plug to fit.
Good luck and keep us posted. If you do it document the process and pitfalls.
Old Nov 27, 2025 | 12:59 PM
Slonison's Avatar
{Step by Step} The Tms Accessorizer
So, here's what I would do if I were in your shoes.
The stock port, a flap.
You will follow these instructions to remove the existing power port
https://lib.americanmuscle.com/files/66353.pdf
These are the instructions for people who are installing the push button start. This will allow you to get in / behind it. What I would do ia find a way to modify the stock power port to have a USB mounted to the flat surface of the flap. Then just route that all the way down and under the center console.
HassellCastle
Jul 29, 2022 03:43 AM
Eddie333
Nov 26, 2020 07:00 PM
lakersfreak
Jan 26, 2014 11:34 AM
Dineau
Nov 17, 2012 10:31 PM
caps
'10-14 Interior and Audio
Oct 15, 2010 06:57 PM
