Need Reverse Camera Help
Old May 8, 2014 | 05:31 PM
jim010's Avatar
I installed the OEM reverse camera about a year ago and wired it to my navigation. No issues until now.
I have been having issues with my reverse camera. Sometimes it works, and sometimes it doesn't. When it doesn't work, I get a black screen or really bad distorted screen with interference. Sometimes it won't even go on at all. The nav is supposed to recognize that the car is in reverse and the screen switches to the camera. Before I installed the camera, the screen would go black, but sometimes it won't even do that. I do see a yellow wrench symbol pop up briefly on the LCD screen on the cluster and then go away.
I'm guessing something is wrong with the wiring and I will check it on the weekend. But I can't see why I am having problems with it now after almost a year of no issues. But could it be something else?
Old May 9, 2014 | 03:38 PM
crazietj's Avatar
camera bad?
Old May 10, 2014 | 03:34 AM
Siber Express's Avatar
Originally Posted by crazietj
camera bad?
I would say this also.
Old May 10, 2014 | 11:07 AM
LEXiiON's Avatar
If your camera is bad, I have one to test with. Shoot me a PM
LEXiiON
Old May 10, 2014 | 12:10 PM
jim010's Avatar
Sometimes it works and sometimes it doesn't
Old May 10, 2014 | 12:18 PM
LEXiiON's Avatar
Well, if you want to test with my camera to troubleshoot let me know.
LEXiiON
Old May 13, 2014 | 07:54 PM
Dineau's Avatar
Have you install a Lockpick kit to connect your camera ?
Old May 14, 2014 | 03:19 AM
I do believe he did not need to since the car he pulled the Nav from had it already. I did on mine and had to reverse the video wires to make it work but his was working fine before.
Old May 14, 2014 | 08:06 AM
jim010's Avatar
That's right. I had it in before and worked fine. I did install lockpick back in the summer, and it still worked fine. It is now spotty. One day it is fine, another day not so good. I have not had time to get in there and see what is wrong yet though.
Old May 14, 2014 | 06:59 PM
I am wondering if it is a loose or dirty connection since it is part time. When mine was messed up there was never a good day.
Old May 31, 2014 | 04:52 PM
jim010's Avatar
All fixed. It was a loose connection in the wiring that \I ran under the door sill. I had forgotten that I had to add wire under there because it was too short.
But all is once again good.
Gigantor
May 11, 2023 07:31 PM
earl610
Sep 6, 2015 05:48 PM
302 GT
Aug 17, 2015 08:46 PM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
