Installing OEM 3 stage heated and cooled seats
Old Apr 8, 2019 | 03:22 PM
  #61
scottwrightF1's Avatar
Originally Posted by cholmes1
Thank you, that does help. I am going to start getting parts together so when the mystery is solved I am ready to follow. I will look for the console today and I believe this is the module needed based on the schematic.
https://parts.autonationfordwhitebea...bC12Ni1nYXM%3D
Thank you for your efforts and keeping the project moving forward. If I have more direct questions about the board install I will send a PM.
Originally Posted by jim010
Here is teh part number for the HVAC dash control module from a 2012 Taurus, which is what I was working with:
CG1Z-19980-C
Heater Control 1
2010-12, W/ AUTO TEMP CONTROL, W/ HEATED-COOLED SEAT
Double check, though!
Thanks for the part numbers and info.
It seems the HVAC are hard to find a used one.
I have gather the info from a HVAC:
2010 = AG1Z-19980-C or G or L, BUT these are discontinued. Not sure why, but I would avoid those.
2011 = BG1Z-19980-D
2012 = CG1Z-19980-C
Old Apr 17, 2019 | 04:29 PM
  #62
jim010's Avatar
Did you get the module?
I am starting to button up my wife's car, so I can turn my attention to my own car soon.
Old Apr 18, 2019 | 05:40 AM
  #63
No, I haven't got the module yet, because I can't find a used one. I am still looking.
Old Apr 18, 2019 | 10:25 AM
  #64
jim010's Avatar
I'll pick one up from Tasca next month.
Old Apr 19, 2019 | 04:32 PM
  #65
cholmes1's Avatar
Is one of these also needed for the revised heating and cooling connections or are the wiring harnesses that lead under the console becoming a hybrid of Mustang heat and Taurus cool?
Look at this on eBay
13-16 TAURUS SHO Right Passenger Seat Black Leather Bucket & Airbag 10 Way Track
I also tracked the new parts if used is not the best option
ElementProduct ID: AG1Z-14D696-QRemove $35.49 ×
Seat Cushion HeaterProduct ID: AG1Z-14D696-NRemove $43.90 ×
Blower MotorProduct ID: 8A5Z-19N550-CRemove $119.38 ×
Blower MotorProduct ID: AA5Z-19N550-ARemove $116.77 ×
Seat Back PadProduct ID: DG1Z-5464811-BRemove $171.60 ×
Seat Cushion PadProduct ID: AG1Z-54632A23-HRemove $294.94 ×
Heater ControlProduct ID: CG1Z-19980-CPrice includes refundable core charge ($50.00 per item) Remove $169.05 ×
Dash Control UnitProduct ID: CR3Z-19980-BPrice includes refundable core charge ($50.00 per item) Remove $149.58 ×
Thank you both for pioneering this mod. It will make road trips so much more comfortable
Old Jun 1, 2019 | 08:46 AM
  #66
cholmes1's Avatar
Not certain this can be done cleanly. I think the Taurus heating element will be required to avoid modifying the OEM pad for the blower. Also, if we go all Taurus seat parts I am not certain the HVAC module will communicate cleanly with the controller in our Mustangs. From what I have seen the Taurus’ with the heat/cool option also have rear seat HVAC controls which won’t be possible in ours.
Old Jul 3, 2019 | 04:26 PM
  #67
cholmes1's Avatar
Any progress?
Old Feb 6, 2020 | 09:39 AM
  #68
cholmes1's Avatar
I purchased the HVAC control module from a 2010 SHO during the holiday break. I will hopefully have it installed in the coming months, too cold in Colorado to pry plastic at the moment. Any updates from @jim010 or @scottwrightF1 ?
Old Feb 6, 2020 | 02:16 PM
  #69
jim010's Avatar
This has been on the back burner for so long for. me. I haven't even ordered the HVAC module yet.
Old Feb 9, 2020 | 10:03 PM
  #70
That great you got it. I still have not found an HVAC or other parts yet and I haven't had the time to do it. Jim had sent me a few photos of the wiring schematic diagram for the HVAC control module awhile back that he had drew up a rough sketch that may work. I decided to put it into AutoCAD to get a clear image. I have attached a PDF of the wiring, but someone has to review it to make sure everything looks okay on the wiring diagram as it might not be right. If you have time to review it. Please leave any commands or what needs to be fixed?
File Type: pdf
Old Feb 10, 2020 | 09:26 AM
  #71
jim010's Avatar
Diagram looks good Scott.
The only thing that may be an issue is the wiring does not go to the smart junction box. The wires for the HVAC are supposed to go to the smart junction box. They are MScan signals. This is where the problems may arise.
Old Mar 12, 2020 | 02:19 AM
  #72
joser_r_britto's Avatar
Keeping a close eye at this mod. I hope you guys can make it work as if it were stock. I will definitely install the three stages heated/cooled seats if doable.
Old Jun 8, 2020 | 10:58 AM
  #73
jim010's Avatar
Cholmes, Scott, any luck so far?
Old Jun 8, 2020 | 11:24 AM
  #74
jim010's Avatar
I bought my HVAC module. I already have the module for the seat, so now I need a blower motor. Eventually will need 4, plus ducting.
Old Jun 8, 2020 | 12:04 PM
  #75
cholmes1's Avatar
Sorry, since the baby was born I have not had a chance to do any of my own projects yet. I have the Taurus HVAC module but still have not had any time to test it. Sounds like you have collected quite a few parts so hopefully you have some success.
Old Jun 8, 2020 | 12:10 PM
  #76
jim010's Avatar
Congratulations! Your first?
I only have the HVAC module on its way, and the seat module. And the wiring figured out. Nothing else.
For the wiring, as stated before, in the Taurus it has to go to the Taurus's smart junction box and then to the seat module. I am hoping that there is no issue there, otherwise we need someone to build a module to translate the signal being sent to the seat.
Old Jun 8, 2020 | 12:21 PM
  #77
cholmes1's Avatar
Once you get your trial underway, if we need to pool funding towards a reputable module I am in...
Knowing that you have had some issues in the past, I trust your judgment on finding someone if needed
Old Jun 9, 2020 | 09:20 PM
  #78
Hey, no sorry. I have been crazy busy and I have not had time to do such things. I am still having a hard time looking for used parts. I may consider getting "new" parts. I was thinking of trying to get the Taurus completed seats and take all the parts off it, but it would be expensive to ship to Canada.
Good congratulation your baby!
Let me know how things go with the heat and cooling setup.
Old Jun 10, 2020 | 09:08 AM
  #79
jim010's Avatar
If this is the route to go, it will be hard to find someone that can actually do it. I did know a guy some years ago on this forum (zeroaviation)!, but he disappeared along with all my parts I had sent to him, so I'm very reluctant to do that again.
Old Jun 25, 2020 | 06:56 PM
  #80
jim010's Avatar
Just came in the mail 😊
