Installed rogue radar detector mount today
Old Jun 14, 2012 | 11:24 PM
JPMotorSport's Avatar
Hey. Installed the rogue mount I just received today. Best price compared to all the others and comes with a seamless cord to draw power from the autodim rear view mirror.
Was able to set it up with my 9600ix - works well and super stealthy. Better than a suction cups on your windshield and no cables blocking your view!
Attached Thumbnails Installed rogue radar detector mount today-image-1633311848.jpg   Installed rogue radar detector mount today-image-2331761493.jpg
Old Jun 15, 2012 | 12:35 AM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
stealthy its not
Old Jun 15, 2012 | 01:00 AM
Shifterboy45's Avatar
its a bit stealthy -- better than a mount on the windshield... now thats a dead giveaway
Old Jun 15, 2012 | 02:27 PM
Stealthy - for less than $700 and handling installation yourself.
Old Jun 15, 2012 | 05:36 PM
denlem's Avatar
Mine was a little more stealthy up and out of the way...
Old Jun 15, 2012 | 09:51 PM
Cusp's Avatar
Rouge mount is a good alternative to the Blendmount for mounting Escort/Beltronics RADAR Detectors. I have one of both and posted a review on radardetectorforum.org.
Old Jul 9, 2012 | 08:58 PM
farmboy90's Avatar
What size rogue mount fits the mustang (3/4" or 7/8")? I assume the 3/4" version??
Nevermind, I found that it is 3/4" from the info in Cusp's great review he linked here.
Old Jul 11, 2012 | 01:05 PM
908ssp's Avatar
I just mount mine on the dash board. Can't be seen from behind. I just wish I had a small straight cord for it. I don't have to unplug it from the power socket in the dash anymore since I figured out a way of making the power socket switched.
Old Jul 11, 2012 | 02:04 PM
2012WhiteGT's Avatar
You might want to check that in your car specifically with some calipers. The auto dimming mirror in my '12 GT premium is definitely 7/8". I think the base may be 3/4.
Old Aug 3, 2012 | 08:47 PM
JoesCat's Avatar
I'm searching for a write-up to tap accessory switched power, probably from the A piller or overhead maplights for mine. I'm in a search now and this thread came up. Denlem has it exactly as I'm seeking.
Which wires to tap into for positive / negative? I really want it switched on in the accessory key position so I don't have to manually turn the detector off.
TIA!
Old Aug 4, 2012 | 01:12 AM
etc1006's Avatar
Some detectors now have an auto off if they don't sense the small voltage change of the vehicle running or no movement, too.
Old Aug 4, 2012 | 09:12 AM
denlem's Avatar
TIA!
I ran the wire through the headliner over to the passenger side A-pillar and down to the fuse box. I don't know how the headliner is held up there, so I sorta just tucked the wire in. The plastic on the pillar is just clipped in so that can easily be pulled out. Just tuck the wire in there and then you need to feed it through at the bottom to reach the fuse box.
Remove the foot panel to access the fuse box. The fuse box is also covered and taped and velcroed. I just removed the tape. There is also a plastic cover on the box. That needs to be removed and you probably won't be able to put that one back on since the fuse tap won't allow it.
From there I looked up which fuse to use in the manual. Unfortunately it doesn't say which are only one with the ignition. I did find one that was ignition only and that is what used. The position can be seen in the pic below.
Attach the detector wire to the fuse tap, pull the fuse out the fuse box (good luck with that) and plug it into the fuse tap. Then put another fuse into the tap. You need two. Your original, and one for the circuit you're adding. Be sure to pick up some spares when you buy your tap.
The ground was simple, I just used the bolt at the bottom of the fuse box. My terminal wouldn't fit over the post, so I just did a partial connection and all is good.
So now there are no wires hanging down, and the radar detector only comes on when the ignition
Old Aug 4, 2012 | 10:56 AM
Thanks for the tip denlem! Never heard of fuse taps before...
Old Aug 4, 2012 | 11:45 AM
denlem's Avatar
Wow, they've been around for a loooong time!
Here is one from Advance Auto Parts.
http://shop.advanceautoparts.com/web...mann_5080114-p
Old Aug 7, 2012 | 08:03 PM
JoesCat's Avatar
That's awesome, thanks Denlem. And I like that the way you did it there no cut or tapped wires to conflict with warranties and such. And can be easily removed whenever.
I like it! I guess I should make up a cord for my V1 ahead of time using a telephone plug like I did before (that one's tapped so staying with the old car), or maybe I'll go ahead and order a wiring kit from Valentine.
Now if only the car would get here . . . hurry UP!
Old Aug 11, 2012 | 02:13 AM
tehMoose's Avatar
Mine is quite stealthy, you can't see it without sticking your head in the car, and it is VERY difficult to see when standing in front of the car.
I also hardwired mine the same way that Denlem did.
DarrenGT
Aug 28, 2015 10:01 AM
GLOCKer
Aug 13, 2015 09:55 AM
glo106
Aug 11, 2015 08:29 AM
trackpack13gt
Aug 8, 2015 11:23 AM
Kgilly
Jul 9, 2015 01:47 PM
