HOWTO: Aftermarket Backup Camera on OEM Navi WITHOUT using Lockpick
Hallo,
Hab mich extra für deinen Beitrag registriert
Echt super erklärt
Auch wenn mein English nicht das Wahre ist
Erinnerst du dich noch welchen Wert du im As-Built geändert hast?
Ist dieser Wert bei jedem Mustang gleich wenn man eine Kamera hat ?
Habe leider keinen Zugang zu einem anderen Mustang der die gleiche Ausstattung hat.
Über eine Antwort würde ich mich echt freuen. Mit freundlichen Grüßen
Echt super erklärt
Hello there,
Hab registered myself specially for your contribution
Real declared super
Even though my English is not the truth
Do you remember what value you in as-built changes have ?
If this value at each Mustang same if you have a camera ?
Have unfortunately no access to another Mustang has the same equipment .
About an answer I would be really happy . Best regards
Real declared super
You can contact Brad at www.4Dtech.com
They can program your nav with the proper asbuilt data to get the camera working.
Otherwise, I recommend the Lockpick:
www.coastaltech.com
Hallo,
Echt super erklärt
Echt super erklärt
Hoffe das hilft.
The problem is, that if you car didn't have the NAV from factory, you can't change the as built on it. Only 4dtech can do it that way. If you car came with the NAV, look on ebay for some VINs of Mustangs with NAV and go to motorcraftservice.com to obtain the as-built for those vehicles. Btw, you can't change an individual value, as they come with a checksum.
Hope this helps.
LEXiiON
Hello All,
I know this thread is a little old, but I'm hoping I can get some advise on installing an OEM Rear Camera Spoiler Part #AR3Z-6344210-BA, so far I have purchased the spoiler camera, and the pigtail connector (my car does not have the harness in the trunk unfortunately).
The Car I have is the 2013 Mustang GT Premium, with the Sync Navigation Display, from what I've been reading, I will likely have to get a lock pick to install the rear camera into to get it to work with the Nav System
Originally Posted by JL_Ware
Hello All,
https://www.4dtech.com/rear-camera-p...-1-nav-radios/
That said I'd still consider lockpick or NavTV.
Thanks Berserk, I did have a look into this one as well, I still need to figure out how to make a harness that will plug into the Programmer if necessary, the lock pick seems to offer more option on the setup, figure, if I have to buy a programmer, might as well have the option to do everything if needed
Hello, I've been wanting to do what you did to your car for along time. Thank you so much for the information...Great write up... Is there anyway that you can send me the video, it has been removed from YouTube. . If you are a tall guy like myself you may be interested in my DYI project..I don't have great pictures because I did not know that I would end up putting on a web site. http://www.allfordmustangs.com/forum...t-group-3.html I am Maggie111 on the forum. Thank you so much for your time and consideration... I've been trying to find a local sound shop to do what you did..No luck. But, with your help I will do it myself...Thanks again,,,
Sep 24, 2015 08:15 PM
