Glow wire install
Old Jan 12, 2014 | 02:30 PM
  #41
CCTking's Avatar
We ran the wiring all into the headlight fuse wiring behind the head light control panel. Each side has it connected to its own power box. The glow wire only turns on when the parking lights or headlamps are turned on.
Nice! I always have my parking lamps on just because it helps add a lil daytime visibility (did it all the time with fogs on as well with my 02)
I have a glowing charger too that would match perfectly
(Not my cable but its the same thing)
Old Jan 14, 2014 | 12:44 PM
  #42
Clue's Avatar
What brand/manufacturer? What actually holds it in place?
Old Jan 15, 2014 | 06:05 AM
  #43
2011 Kona Blue's Avatar
http://www.glowire.com/categories/Ca...%7DMotorcycle/
^ Here is the company I ordered it from. You want to get the power pack combo kit.
The wire on the dash board and door panels are help by itself. They were tucked into the tight space and the wire stays in place. The wire around the speakers, that was a bit more tricky. At first we used hot glue on the panel and after a week or so the wire peeled off. This time we thought outside the box. We drilled tiny holes into the door panel abound the speakers in that grove and placed a small zip tie around the wire and pulled it tight.
Old Jan 28, 2014 | 02:44 PM
  #44
MDkid92's Avatar
Looks great! I think it'd be much better if it were a darker blue as well! To everyone, Dodge Dart (don't know which models) has this. Comparing the two, very nice job!
Old Jan 28, 2014 | 03:58 PM
  #45
That red looks sweet. I think that is the darkest blue they had. Its matches the color of my speed odometer which I was hoping for.
Old Feb 3, 2014 | 09:37 AM
  #46
DeeJayTJ's Avatar
im kinda confused by what you are saying here.
Are you saying you tapped into the wire harness directly at the headlight switch?
for park lamps i think its a gray wire - and it would be fused at that point. OR did you tap into your interior light wire? because the park lamp wire would not allow the dimmer to affect the interior lights.
Just trying to understand because I am about to install a very factory looking ambient lighting setup to an RGB controller and want the lights to turn on whenever the interior panel lights are on as well as when park lights are on.
Old Feb 13, 2014 | 01:03 AM
  #47
Shelby Mama's Avatar
To heck to what everyone else has to say. I really like it and you did a really great job of installing this piece. Kudos to you Kona!
Old Feb 13, 2014 | 07:32 AM
  #48
Thanks man. Really appreciate that.
Old Feb 13, 2014 | 11:51 AM
  #49
DeeJayTJ's Avatar
so which wire did you tap into?
i tried using a purple/white wire for what i thought was supposed to be park lamps because using a multmeter, it shows power in the on position and nothing when off.
but its not working for me to a relay.
Mr. Sparkle
Sep 11, 2015 02:57 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
