Bypass factory amplifier
Old Dec 4, 2014 | 10:25 AM
jonb2's Avatar
Hi,
Have stock radio (non shaker) in 2013 Mustang V6. Would like to install aftermarket amplifier. Is there any way to bypass the amplifier in the factory radio? Is it internal and therefore can't be bypassed?
thanks!
Old Dec 4, 2014 | 10:40 AM
awoychosky123's Avatar
If you dont have a shaker system you dont have a amplifier.
Old Dec 4, 2014 | 10:47 AM
jonb2's Avatar
Ok now I'm really confused. There has to be an amplifier somewhere. Maybe built-in to the head unit and can't be bypassed?
Old Dec 4, 2014 | 11:13 AM
Joeywhat's Avatar
Speakers are fed direct from the head unit. No standalone amp.
Old Dec 4, 2014 | 11:14 AM
Joeywhat's Avatar
If you want a clean, unamplified source you will likely need an aftermarket head unit with preamp outputs. Don't think any factory head units offer such a feature.
Old Dec 4, 2014 | 11:53 AM
05PRMTX's Avatar
Yep, or you can get a sound processor to clean up the signal from the factory head unit
Old Dec 4, 2014 | 11:55 AM
05PRMTX's Avatar
Almost all head units have some sort of internal amp, unless its a high end SQ head unit.
Old Dec 4, 2014 | 12:01 PM
Joeywhat's Avatar
Yes, but most aftermarket head units do offer preamp outputs. So at least you have the option.
Old Dec 4, 2014 | 12:17 PM
05PRMTX's Avatar
Right, I guess I should have specified factory HU. What I was getting at is almost any factory head unit is going to have an internal amp. So he either has to get an aftermarket one to gain the preouts, or get a sound processor to clean up the factory signal
Old Dec 4, 2014 | 02:09 PM
jonb2's Avatar
Thanks for all the replies. If I go with sound processor how would that work? Take speaker outputs from HU into the processor and then processor out to car wiring harness and 4 speakers? Or do the outputs have to go to an external amp and then to 4 speakers?
Since I'm not really bypassing the internal amp, would I just be "boosting" the factory internal amp in the HU?
thanks!
Old Dec 4, 2014 | 02:43 PM
Joeywhat's Avatar
thanks!
Some processors do allow you to connect speakers directly to it, or connect an amp via preamp outputs. It would depend on how much power the speakers need.
It's not just boosting, it alters the incoming signal. If it was just boosting it it would just be an amplifier.
Old Dec 9, 2014 | 12:15 PM
05PRMTX's Avatar
^^What Joeywhat Said. Factory radios typically come with low watts and a filtered signal to keep the crappy stock speakers from blowing up. A sound processor will take that ugly signal and clean it up, so you have a full, unfiltered, signal to send to the aftermarket speakers/amplifiers.
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Feb 10, 2017 07:12 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
Sep 10, 2015 12:44 PM
