Been at this for 12Hours Straight
Old Mar 17, 2012 | 11:12 PM
nighthawk283's Avatar
I been trying to hook up my new HU and everything is wire right but i am not getting no remote power for the HU to power on when the ignition is on. i have check the fuses and there all good. if i plug in the old HU it turns on but my aftermarket one gives me no power. can you guys show me what wire harnesses you used for how you got it to turn on with the ignition thanks. and the HU is good because if i give power to the remote wire from the HU to the constant Hot it will turn on. Which wire is the remote hot wire.?
Old Mar 17, 2012 | 11:50 PM
Boss 1409's Avatar
INKY
Did the harness not come with instructions? When I installed mine it was pretty straight forward and said what colors everything should be. From what I have found on-line it should be a blue wire. You didn't take apart the stock connector did you?
Old Mar 18, 2012 | 10:25 AM
Yes my harness came with instruction and it was straight forward and I didn't cut the OEM of the radio wires. And I have no solid blue wire from my OEM harness. Its a 2012 v6 mustang. I check all the lines on the harness with ignition on and the most voltage I got was 5 volts.
Old Mar 18, 2012 | 10:30 AM
Do i need this to get the remote switch to turn my HU on?
Axxess XSVI-5520-NAV Non-Amplified Non-OnStar Harness
Old Mar 18, 2012 | 03:03 PM
Galimore's Avatar
I spent hours getting mine to work as well. After using a voltmeter I realized that the stock power/switched wires on my harness weren't giving me anything for some reason. I wound up using the 12v round plug under the center console for my power and used an add a circuit from autozone for my switched power. Everything worked fine after that.
Old Mar 18, 2012 | 03:17 PM
Boss 1409's Avatar
INKY
I used this when I did the stereo on mine. Didn't have any issues with the remote on.
Old Mar 18, 2012 | 04:55 PM
stupidgenius36's Avatar
Just Plain Rude!
Off topic, but I see you're from west texas...Where exactly? I grew up out there.
Old Mar 18, 2012 | 05:07 PM
Thats what i ended up doing. so not it turns on when the key on is on
i am located in el paso TX
Old Mar 18, 2012 | 05:20 PM
Just Plain Rude!
Ah, well you're waaay farther west than I expected. I never saw a welcome thread for you, so welcome aboard. Glad you got things figured out.
Old Mar 20, 2012 | 11:06 AM
Mossberg's Avatar
edit: nevermind
Road_Runner
Sep 2, 2024 04:46 PM
OneCoolGT
Dec 10, 2015 07:55 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
