Adding the OEM nav
Sorry, allow me to clarify - I swapped out the dash harness in my base 11 for the nav install. All of that is fine. I have an 11 sync module all plugged in, but Im not getting anything out of it. Have had a steering wheel button on back order for 3 months now...thanks COVID...so havent been able to try that.
Epiphany last night was to check my SJB to either see if I have the fuse, or if it needs to be reprogrammed potentially...
Wish I could help. As far as I'm aware, it should work without doing anything else. But you don't have the switch to activate sync either. And GPS does not work either. By not work, you mean no map, or map but does not move when moving?
The map is moving based off the internal ACM dead reckoning, but no satellites and therefore no GPS position updates. Its picking up the SiriusXM just fine though. I left the GPS module under the dash out, my understanding being it is not needed per the nav swap instructions early in the thread - Ill probably order one up and see if that does the trick anyway. Otherwise - this is my second sync module and second GPS antenna, leading me to believe its a programming thing, or maybe something Im missing regarding the SJB. As time and resources allow - Ive only been able to really attack these issues piecemeal every couple of months or so, and while none of it is really a problem right now - Id really just like to get it all complete at this point. Have an old fastback that needs attention, too...
OEM nav on 2010 GT
I followed the steps on my 2010 GT premium and everything seems to work fine except The engine wont crack. I see 3 plugs that i have no idea where they should go. One plug should be plugged to the steering wheel position sensor right above the ignition switch. I looked at the old plug its smaller than the new one! The other two plugs are under the cluster.
This is the number for the harness i bought
The ER3Z-14401-KA
I followed the steps on my 2010 GT premium and everything seems to work fine except The engine won’t crack. I see 3 plugs that i have no idea where they should go. One plug should be plugged to the steering wheel position sensor right above the ignition switch. I looked at the old plug it’s smaller than the new one! The other two plugs are under the cluster.
The ER3Z-14401-KA
That won't work. The ER3Z is a 2014 and doesn't have the Steering position switch, as that is in the EPAS. The two plugs are for the new 2013/14 Amp. So you need to get one off eBay to get it run. Although all the plugs at the steering wheel are identical, so except the one for the position switch should plug right in..
Worst case you need to get a 2010 dash harness. There are substantial differences between 2010 and 13/14
I may still have a 2010 GT NAV dash harness... however I think I wired a amp to it, so it may be a little jacked on the passenger door connex.
LEXiiON
Log it - another successful swap. FINALLY.
Color me a ******* - after entirely too long, cross country move complete and settled in, finally got a few hours of alone time...and decided it was time to rip everything out and try to see what I could see in terms of why I could get everything except GPS. Well...luckily didnt have to get far, the purple GPS wire from the antenna splitter wasnt secure in the ACM and was hanging loose. One little click into place, fire her up....boom. A year + for just that. Wish I had more time, more often haha. Now just need to wire up the sound and get sync working and shell be all done. But as far as navigation goes - my formerly base model is full up. Thanks again all for the help!
My hope is to eventually join the ranks of all those who have successfully upgraded to the OEM Navigation. Several relatives are questioning my sanity but this is going to be cool when completed. My Mustang is a 2013 GT Premium. I have all the needed parts for the upgrade - the part for upgrading to a dual climate control took 4 months for it to ship from the factory. So I am ready but I have hit a snag. We cannot get the dash out. I believe we have removed all the necessary bolts, nuts and screws but it is hung up somewhere towards the windshield. How on earth do you remove the sun sensor next to the windshield? I can not find a way to unplug the thing from under the dash, my hands can't get up there.
I want to make sure I am seeing what I am supposed to be seeing. When the dash comes out it has all the ductwork, the steel bracing and most of the wiring harness. Is this correct? I don't know why this is being so difficult for me. I have a good mechanical background but this dash is kicking my rear end. I am finding that at 67 it is not as easy to roll my 6'3" frame up into the underside of a dash but I believe we managed to get everything disconnected. Been working on this for two weeks. I would appreciate any help that any of you can provide. Thank you,
Rick
Rick
I had gone by the dealership a week ago and one of the service writers printed the instructions out for me. A few months ago I spent the big bucks to buy the DVD based shop manual from the publisher. I popped the DVD into my Windows 10 system and loaded the program only to find out that the program does not run well under Windows 10. I tried it on Windows 8, 7 and Windows 98. No go. I am the systems administrator for a none profit I work for so I found an old Windows 95 laptop that was supposed to be destroyed. The program runs fine on this old laptop but is difficult to use on the smaller screen. I finally bought the $10.00 PDF version and it turns out to be a great easy to use version.
This morning I printed out the section from the PDF file, which was better than the dealer printout, and used it as a guide to look over what we had done so far. Unplugged all the harness plugs and my brother-in-law and I gave the dash one more try - out she came. This has been a very interesting process. I could not have pulled this off without the advice and instructions and the experiences of all the people on this site. Thank you everyone, I truly appreciate it.
Rick
Rick
We got the proper documentation and got the dash out. I had a printout from the dealership but it was missing a few pages. I bought one of those PDF file workshop manuals on eBay and printed out a much better version of what I went to the dealership for. We are in the process of switching out the dash harness. I have a question that perhaps someone here has seen. As we are pulling the old harness we are plugging in the new one I ran into a place where there is not a matching plug on the new harness. Up under the dash, driver side next to the center vents there is what I believe is a GPS module. The new harness does not have a plug for it. What is this for? Does the navigation handle GPS in a different way? I seem to remember reading something about this on this forum but I cannot remember exactly where it was. Thanks,
Rick
Rick
