2014 GT wiring harness
Old Jan 18, 2015 | 07:44 PM
Jazzman442's Avatar
Does the audio system in the cars have the same wiring harness?
I have the Nav system and I am wanting to install a sub in the trunk. Does anyone know if the wiring is there for this?
I have extra wires in the Spare wheel area?
Old Jan 25, 2015 | 10:02 PM
Jazzman442's Avatar
Really out of all the people on this forum and nothing? GEZ!!
Old Jan 26, 2015 | 05:55 AM
shouldhavegottheGT's Avatar
If you are adding an aftermarket sub you need an amp kit and a line out converter.
Its pretty basic to install if you're familiar with car audio. I know there are a few how to's in the audio section.
Run the amp kit from the battery to the trunk. Tap line out converter to rear speaker. Tap remote wire to antenna wire. Hook up all the wires and start bumping.
Old Jan 26, 2015 | 07:30 AM
Jazzman442's Avatar
I was just wondering if there was a harness already run for the Sub Out? I can not imagine them running a separate harness just for the Sub?
Old Jan 26, 2015 | 08:40 AM
jim010's Avatar
Chances are, there would be separate harnesses. I found this out when doing my navigation retrofit. Best bet is to talk the the parts guy at the dealer to find out.
Old Feb 2, 2015 | 10:24 AM
WhiteBird00's Avatar
Why not just go in the trunk and look? The dealer parts department is unlikely to know unless you get an enthusiast behind the counter - most parts people don't have a clue beyond what's listed in the manual. The parts will be listed with part numbers but there will be no mention in the listing as to whether the harness would be installed in all cars or only those with the option. The best you can hope for would be finding out if it's part of a larger harness and if that harness is the same for all models.
For example, fourth generation F-bodies all had the harness for the remote CD changer regardless of whether that optional changer was installed. But if you look in the parts listing it just lists the part number with the notation "with CD changer"... there would be no way to tell that it was actually in every car.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Gill5oh
Oct 6, 2017 10:50 PM
Fedupdave42169
Oct 23, 2015 09:58 AM
