2014 Gt + Tech/Sync Pkg Climate Issues?
Old Dec 16, 2017 | 11:17 AM
galaxius's Avatar
I have the GT Base + Tech/Sync package, no heated seats or digital climate control, and I've noticed that the temperature control **** only does HOT or COLD, there is no inbetween or blended air. I can also hear the exact point where the **** goes from HOT to COLD via the dash ducts closing/opening and letting in air. Is this a standard feature for 2013-14 mustangs without climate control (temperature setting)? It doesn't even make sense to have those ***** with a range if its just hot or cold...At this point, since its winter Im having to turn off the heater or roll down windows 15-20 minutes into a drive because it gets WAY too hot even when I'm just running the front defroster on the lowest fan setting. I've attached a picture with the temp **** marked where it switches from hot to cold and vis/versa.
Note: I've had this issue in the past but now I'm a bit more sensitive to the elements and its bothering me. I also had an issue where the blend door actuator was clicking, the dealer replaced the blend door actuator and the clicking noise went away, but that didn't fix the temp issue, which was there before the blend door failed.
kryptonTJM
Jun 23, 2016 11:34 AM
defiance772
Mar 27, 2014 12:37 PM
Sky Hye
Sep 29, 2012 05:57 AM
AMChief 5.0
Aug 15, 2012 08:15 AM
laserred38
Jul 8, 2010 05:37 AM
