2011-2014 FORSCAN / AS-built spreadsheet
Over the past week I have been working on compiling a database of As-Built codes in order to dissect the programming of the cars.
At this point, I have over 75 cars as built data compiled along with the features that came with those cars. I would appreciate any help that the members here can provide, either with what individual knowledge you have or with those who are better at pivoting data than I am. Here it is below, I will update as I learn more. 2013-2014 As Built Database Link to shared drive of window-stickers https://drive.google.com/drive/folde...2A?usp=sharing |
This Topic Has Some Info You Might Find Useful!
https://themustangsource.com/forums/...topics-551889/ This May Have Some Usable Info For You as Well! https://themustangsource.com/forums/...551885/index2/ The Dtc Section Has a Lot of Module Related Ford PDF'S as Well! https://themustangsource.com/forums/...e-info-550475/ KC |
(Post 7091795)
thanks for posting .... I hope to learn something from this when I can take the time to look at it and figure it out
Now over 140 Cars. I am starting to make headway. Would you believe the presence of the Glass Roof affects AS-Built Data!?
Yes I Would, For Example Verts vs Coupes Have Different Radio Tonal Curves. You Would Be Surprised How Many Different Things Can Affect Programming.
Kc |
21 Attachment(s)
As Per PM Questions!
Rear Park Aid Pdf's! Enjoy, KC Parking Aid Sensor Components https://www.fordpartsgiant.com/parts...ml?pnc=15A862B |
251 Cars added.
Color Coding on the bottom to determine the modules that have been fully decompiled. |
It's been a while since I added an update.
I have successfully decompiled the follow: PCSM - Power Steering Control Module ABS - Antilock Brake System APIM - Accessory Protocol Interface Module (Sync) FDIM - Front Display Interface Module PCM - PowerTrain Control Module Partially Decompiled RCM - Restraint Control Module ICM - Instrument Cluster Module BCMB - Body Control Module B ACM - Audio Control Module (Successfully decompiled how presets are managed in both Navigation and non-Navigation Vehicles) Still Need work: GPSM - Global Positioning System Module GEM - General Electronics Module (basically the BCM) |
Thanks For The Update! Getting Closer To DIAL UP Mods on Demand!
KC |
I have a few testers on board but would like to expand my reach.
I have added a tab called "Bounties" which I am putting out there to anyone with that Target Vehicle who has/is familiar with Forscan. I am looking for testers who would be willing to test out this as built data and provide back feedback on the bounties. We have solidly identified: Rear View Camera in Navigation Activation Parking Assist Activation in the Gauge Cluster Activating or Deactivating Sequential Tail Lights Overriding the Door Sill to GT500 Red Modifying the Language of the Cluster Controlling the Passengers/Drivers Beltminders I have also added a section under Tools which contains the ability to custom build your radio stations and load them via As-Built. both for Nav and Non-Nav. Also, the ability to take your as built and explode it out into the radio stations. |
Go Man Go!
KC :nice: |
(Post 7091831)
Congratulations & Happy Birthday!
Kc |
I have added a calculator for correcting the tire size that is installed on the car if you change your tires. This is currently in Beta but appears to be solid for the cars
https://cimg2.ibsrv.net/gimg/themust...2fad5a7706.png |
This is a truly powerful database. You might find it useful to compare the data with the factory settings. For this, you can use monroney labels at https://carfast.express/en/window_sticker. It shows what was installed at the factory. If you need help analyzing or comparing codes, I'm sure there are people on the forum who can help.
| All times are GMT -6. The time now is 01:31 AM. |
