Will 2013 CS grill fit a 2013 V6?
Old Aug 8, 2014 | 10:35 AM
RIBS's Avatar
Hi all, I have the 2013 V6 MCA edition with the "dark Stainless"which is not dark at all. I want to replace it with the Factory "CS" grill, but no one at Ford can tell me if it will fit. The Dealer says "Non returnable"
So..the grills look the same, one black, 1 silver. Will the CS grill fit in the 2013 V6 Mustang grill opening? Has anyone done this swap?
Old Aug 8, 2014 | 10:40 AM
MDkid92's Avatar
Should be a direct swap. I believe they are the exact same, just that the CS grille is black.
Old Aug 8, 2014 | 08:32 PM
Mickstang's Avatar
What do you plan to do with the MCA grill? Are you just swapping the upper grill?
Old Aug 10, 2014 | 08:55 AM
Toad 185's Avatar
I have been kicking around the ideal of plasti dipping my grill
Old Aug 10, 2014 | 02:21 PM
RIBS's Avatar
I want to replace upper and lower and get a black look instead of the Stainless look...
I was also thinking about the Plasti-Dip but on a grill it seels like a pain to spray, and a pain to remove at a later date.
I would rather just have a Ford grill if it will fit. the Problem is every Ford person I have talked to has no idea if it fits, and the dealers say its NON- Returnable, so its a $475 gamble I am not willing to take!!
Has anyone done this swap??
Old Aug 11, 2014 | 07:42 PM
JimC's Avatar
legacy Tms Member
The 2013 front fascia is the same for V6 and GT, so it is a direct swap.
Old Aug 20, 2014 | 12:41 PM
ssjbuu's Avatar
The 2013/2014 V6 and GT have the same front fascia, the only difference is the style of the grille and the fogs. I put the GT/CS Upper and Lower grilles in my GT and it was relatively simple, just a bit time consuming bc you have to remove the whole front fascia to properly install.
And check out this website to buy from, under $400 for the pair before shipping:
http://www.levittownfordsupercenter....s-c-36_52.html
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
Linkspure
Sep 12, 2015 06:33 PM
