WebElectric One Touch Top Down
I searched and hadn't seen a write-up on it. I bought an OTT-1M10 module from webelectric. About $50.
Installed it today. It ties into the harness in the trunk, pretty simple. After programming, a single touch to lower the top (after releasing the latches) and one touch to raise the top (then latch).
All parts included, easy to follow instructions (although some of the wire colors had changed for my 2014).
A great item to have if you can't be bothered to hold the up/down button for 20 seconds each.
2014 Mustang V6 Convertible, Oxford White
Boy if I had a vert, that is an addition I would definitely want to look into. Cool find thanks for sharing!
hey this is nice. Is it the whole casing as well or just the buttons. Because my clips for the original casing broke off when trying to take it out so i need a new case. If its not do you or anyone else know of any solutions...other than epoxy
