Those who installed their own Roush side splitters
Old Apr 28, 2011 | 05:32 PM
SD6's Avatar
SD6
Question Those who installed their own Roush side splitters
Mine has arrived! I read the install sheet from Roush and it looks pretty straight forward for a non-auto tech like myself.
However I have a question for those who have done it.
Since there is some drilling involved, the car likely needs to be raised up?
Did you jack it up and put 4 jackstand on it, so it remains parallel to the ground? Or how did you do it?
Eg if I'm installing driver side, would it be weird to use only 2 jackstands, one on driver front and one on driver rear?
Old Apr 29, 2011 | 09:46 PM
2011 GT's Avatar
Did the install myself, but with the help of a buddy of mine, who owns a garage. He was so kind and let me use one of his lifts to raise the car up. As my car is lowered, we put it on the allignment lift, which provided enough clearance to drill the holes with no problem. The install is straight forward and very easy, even for someone like me.
Do you have anyone who could let you use their lift for 30 minutes or so?
Old May 3, 2011 | 06:24 PM
losangeles's Avatar
I did it all myself. Used a jack to lift up the rear left side, drilled the holes, then jacked the front left side and drilled the rest. Then the other side. Once the holes are all drilled the car doesn't need to be jacked up if I remember correctly
Old May 4, 2011 | 03:25 PM
RobDis's Avatar
I took my rockers off and painted them and installed the roush splitters on the rockers before putting them back on. No lift needed! But I wanted my rockers painted flat black. Didnt want that awful plastic crap fading on me!
Old May 7, 2011 | 03:04 PM
jacostang's Avatar
It was a snap! 30 mins. top! Ties in the Boss Front splitter perfectly!
Old May 7, 2011 | 04:21 PM
5 DOT 0's Avatar
Photos?
Old May 7, 2011 | 06:04 PM
RobDis's Avatar
Originally Posted by 5 DOT 0
Photos?
Profile....... AHHH ok here you go! But seriously there are some more pics on my profile.
Attached Thumbnails Those who installed their own Roush side splitters-painted-rockers.jpg
Old May 7, 2011 | 08:18 PM
SD6's Avatar
SD6
Don't have the use of a lift unfortunately. Me and a buddy are going to install these and the CS/GT fascia tomorow.
I think I'll try it this way, jack up one side at a time to drill the holes and then do the install.
302 GT
Aug 21, 2015 07:31 PM
glo106
Aug 11, 2015 08:29 AM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
roushcollection
Jul 28, 2015 02:08 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
