Spyshot of the new 2010-2012 Steeda Hood w/ functional vents
Originally Posted by 5 DOT 0
The flow through the radiator is mostly effected by the grill. The vents won't effect engine temp (CHT) much but will allow heat under the hood to escape The Tiger Racing hood significantly reduces lift which increases downforce. It does help with heat dissapation but that's not it's main function.
Are there two variations of this hood ? In the last picture of this thread, the vents appear near the front of the hood. In all the previous pictures, the vents appear at midpoint in the hood. Regardless of where the vents are, I think the new hood is very stylish and I would buy one over any hood currently on the market. I also like the height of the hood, perfect ! !
No they are in the same position. Just one of the photos was taken with a cell phone and the others were taken with a better camera at different angles.
This hood will vent some under hood pressure and of course heat, it is no where near as effective as another hood on the market, and it was not meant to be.
It does an adequate job for street use, and it is better than stock for the driver that does an occasional track event. It has function, but it is was not designed to be extreme.
Its primarily function is looks with the added benefit of reducing some heat. You get the best of both worlds but more looks over extreme functionality.
I am Shauny Clause
MOTM July 2010 Winner
do you need hood pins with this hood?
Is it AL or FG?
I am very interested
do you have any pictures with it all painted one color to share?!
Is it AL or FG?
Another question I thought about....is this hood a traditional "Cowl" style where it releases air from behind the "powerDome" at the windshield...or are the only air vents the ones we see on the sides?
Meant to chime in earlier but I'm going to be the naysayer here. I think the hood looks awful. Even if functional I can't get over the looks. What I WOULD like to see is a hood like the 2013 GT hood. I love the look of that hood.
The hood is Fiberglass. Hood pins are not required. No pictures painted one color at this time.
The hood is also open in the back where the rise is at the cowl, so it moves air both our the front vents and through the rear cowl.
We have had great feedback on the hood and thanks for the orders thus far!
TJ
TJ
Any wind tunnel+smoke testing to see how air is really being moved? That would be the only way to see how much air is extracted through the vents, and inducted via the cowl induction.
Somehow i see this as hurting instead of helping. I have a feeling it doesnt move as much air as it appears to.
I agree the cowl would be better off closed when moving it will release heat when standing still like at a drag race. I think the hood looks fine and they make vented hood with a larger vent and no dome. But the dome can be useful for someone needing more hood room for a tall supercharger install.
The rear cowl works just like someone else described a few posts up. Air flows IN to the engine bay from the back of a cowl-hood. Right at the base of the windshield is a high-pressure region where the air over the hood meets the windshield.
Air from the front vents is lower in pressure compared to what is underneath so air is allowed to flow out the vents from underneath.
This is why the GT500 has a vent across the middle of the hood in a similar front location, to flow air from the inside, out.
The air coming in through the back does not force its way up front and block the airflow there, it all works just fine.
Besides computer airflow modeling validating the real world airflow is easy. You put some streamers on the back of the cowl and just go for a drive, as soon as you start passing 50 miles per hour or so you will see the streamers start showing the airflow into the cowl. Piece of cake.
