Removing plastidip from hard to reach places
Old May 15, 2013 | 07:02 AM
Brandon302's Avatar
Has anyone used Goo Gone or brake clean or some sort of solvent to remove plastidip from hard to reach spots without ruining clear coat?
Old May 15, 2013 | 01:10 PM
Rando's Avatar
I'm also interested
Old May 15, 2013 | 02:43 PM
Mikey's Avatar
I just removed it from my hood vents, it was a huge pain. I sprayed the layers too thin and I couldn't get much of it to peel off at once. I ended up using a credit card and small plastic tool like a scratch art knife to scrape it off and my fingers to rub it off... I wouldn't use goo gone or adhesive remover like products, but that's me
Old May 15, 2013 | 02:48 PM
adrenalin's Avatar
Depending on where the plastidip is that you are trying to remove, what about using a small plastic pipe cleaner? I have seen some that are completely plastic (no metal), which should prevent scratching. Goo Gone and other adhesive removes can damage the clear coat if left on too long.
Old May 15, 2013 | 02:52 PM
det97's Avatar
Brake cleaner melts paint like butter. I used to use it gently on door scuffs from other cars. It can be used, but its like a nuke when a credit card will do.
50Cal
Sep 17, 2015 06:43 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
jim010
Sep 14, 2015 10:15 PM
Grabber5.00
Sep 13, 2015 06:53 AM
Sep 10, 2015 12:44 PM
