Rear Deck Trim Removal 14
Old Apr 28, 2013 | 11:40 AM
CamsGt's Avatar
any removed this shiny plastic trim piece?I see videos of 10-12's but mines different.I see 2 little screws.I am sure i have seen the rtr for sale for 14 but not sure how hard it is to get stock piece off.
Old Apr 28, 2013 | 04:16 PM
mikeyt03's Avatar
Unscrew the two screws and start tanking from the top corner.
Old Apr 29, 2013 | 10:19 PM
Raydin_27's Avatar
yep mikey has the idea, remove screws and just start pulling straight off, theres alot of clips.
best video to show you is this:
heres the install sheet from cdc, have fun cutting up your trunk.
http://www.classicdesignconcepts.com...ll%20guide.pdf
Old Apr 30, 2013 | 08:08 AM
CamsGt's Avatar
nice video thanks! after watching I'd be concerned about water running down the back into the holes and into trunk.
actually thinking about taking lid to body shop and have them fill in all holes and match the paint.either that or getting it hydro dipped
Old Apr 30, 2013 | 05:52 PM
Raydin_27's Avatar
well to be honest, i have that carbon decklid panel, and its been a pain in the *** since. i put it on and there as a bit of a gap at the top (must not have stuck it on just right)so every time i shut the trunk it flopped around, PLUS to add insult to injury, it started to peel off just a few days after. so not wanting a $300 carbon fiber kite on the highway i pulled it back off (with little effort by the way) and put new 3m tape all the way around and stuck it back down, it fits much better now but the one corner is still starting to peel up again, i dont know if it was just too cool when i put it on, but i might pull it off one more time if it gets worse. then if still no luck, back to stock i go.
Old Apr 30, 2013 | 07:21 PM
mikeyt03's Avatar
Happened to me too. It's because the panel isn't exactly made for the 2013 and there is one corner that doesn't sit well. I used adhesion promoter on the corners and it helped. I too hate how it rattles when I close the trunk. I thought about taking it off and getting the rtr one.
Mpaps
Oct 11, 2017 08:06 PM
Fords4Ever
Oct 30, 2015 09:07 PM
dblhelx
Oct 6, 2015 08:08 PM
seaclam
Sep 25, 2015 01:29 PM
Sep 8, 2015 10:45 AM
